Suspension sway bar
Old Nov 6, 2006 | 01:57 PM
joecooper's Avatar
joecooper
sway bar
im lookin in to getin a rear sway bar i auto cross the car but it is also daily driven what do u guys think i should go with from ur exprience
Old Nov 6, 2006 | 02:09 PM
agranger's Avatar
agranger
A rear swaybar is a frequent addition to an AutoX car as it helps promote rear-end rotation. I would consider getting an adjustable one (with the 3 holes on the end or a sliding model like Randy Webb's or the one from Ireland Engineering) so you can dial it back for your day-to-day driving.
I've got the H-Sport Comp bar on my car and I'm loving it. I leave it set on the softest setting most of the time for day-to-day driving as it is more agressive than most aftermarket rear-swaybars out there.
If you have jackstands and basic hand tools, the install is fairly easy and should take you about 2 hours your first time through... 1 hour or less if you have done it before.
How-to from Randy Webb: https://www.northamericanmotoring.co...ead.php?t=4372
How-to from Outmotoring: http://outmotoring.com/How_to_rearswaybar.html
A video how-to I created a while back at a wrench-a-thon in my driveway (not perfect w/ the termanology, but it's a great overview): https://www.northamericanmotoring.co...o+rear+swaybar
Old Nov 6, 2006 | 02:11 PM
txwerks's Avatar
txwerks
19mm H&R... bar none... How punny!
I've run the 19mm H&R for 3 years now... The nice thing is that the bar allowed me to grow into it - and, as I made other changes, it's been a great match. With the current setup, it's still perfect. I've never wanted more, at any stage of suspension development.
IMHO, way, WAY too many people out there are running way too big a rear bar...
Old Nov 6, 2006 | 02:15 PM
agranger's Avatar
agranger
I'm one of 'em, but I liked the Zerk fittings so I could lube the bushings without removing the bar. I also got a killer deal on it from a special that H-Sport was running at MOTD 2006.
The Texas Speed Werks guys (txwerks) know a heck of a lot more about suspension setups than I do...
Old Nov 6, 2006 | 02:23 PM
kenchan's Avatar
kenchan
22mm on stiff setting does it for me.
Old Nov 6, 2006 | 02:27 PM
Eric_Rowland's Avatar
Eric_Rowland
And I like the 22mm on full soft.
YMMV.
Old Nov 6, 2006 | 02:33 PM
#20Works4me's Avatar
#20Works4me
Just ordered my 19mm H&R after reams and reams of post reads on this subject (99% street use), bonus of this bar well mostly the fittings is there is no lube necessary as they use an exclusive urethane/Teflon bushings
Old Nov 6, 2006 | 02:34 PM
billie_morini's Avatar
billie_morini
I have a 22mm diameter sway bar. Setting for street is middle. Difference is obvious; even for street.
Old Nov 6, 2006 | 02:37 PM
txwerks's Avatar
txwerks
I like the H&R's bushings - which never need greased.
And, the 19mm H&R works with everything from OEM to a full race suspension...
Old Nov 6, 2006 | 04:03 PM
joecooper's Avatar
joecooper
does anyone have the alta swaybar and if so do u have to grease it or do u just and install and keep on motoring i really like the idea of the h&r just install and drive no maintenance
Old Nov 7, 2006 | 07:01 AM
ECHO-313's Avatar
ECHO-313
I have an Alta bar. It came with 3 holes..I thought it was only going to have 2...bonus
I set it to the stiffest setting and I love it.
Quick question- If you add camber plates (I would like -2) do I or should I back off on the rear bar? And why?
Old Nov 7, 2006 | 07:05 AM
ECHO-313's Avatar
ECHO-313
Sorry, I didn't answer your question
No I dont grease it. When I put it on, I wraped a little teflon tape (thread tape for pipes) around the bar before putting on the bushings. 10.000 miles and all is well
Old Nov 7, 2006 | 06:54 PM
txwerks's Avatar
txwerks
It somewhat depends on what your rear camber and front and rear toe will be set to... But, yes, in general you'll find the car very tail happy and twitchy with that bar set to full stiff...
Old Nov 8, 2006 | 06:35 AM
ECHO-313's Avatar
ECHO-313
My rear camber is -1.5 with 0 toe. I would like -2.0 camber front with a very little 1/8 total toe out.
If I do this should set the swaybar to the middle setting? I like the way it handles now. The reason I want camber plates is that when I hit a corner hard (like a freeway cloverleaf) the front outer tire feels like it would be the first to break free. Would camber plates do the job.
SORRY BOUT THE HI-JACK
YaTuSabe
Aug 23, 2018 11:41 AM
gar56
Nov 15, 2016 06:41 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
mauiguyharry
Oct 8, 2015 06:53 PM
