Navigation & Audio where to put the amp (not killing my trunk)?
Old Nov 2, 2006 | 01:55 PM
MiNi_MaC's Avatar
MiNi_MaC
Any idea on where I can put my amplifier without sacrificing the trunk space, if there's any lol (pictures are more then welcome ).
Thanks,
MaC
Old Nov 2, 2006 | 01:59 PM
clarkdr81's Avatar
clarkdr81
Yea I was gonna say, what trunk space? Would there be room under one of the front seats?
Old Nov 2, 2006 | 02:12 PM
Motoring's Avatar
Motoring
There is room under the front passenger seat. But not for a huge amp. There is a significant amount of padding under the carpet. You will have to do a little digging to get the available dimensions. Someone posted their installaion several years ago. You should be able to find it. Or you can always pull the seat, pull up the carpet and measure for yourself. Remember to have the ignition off when you disconnect the seat wiring, and do not turn the ignition back on until you reconnect the wiring. (or else the Airbag warning light will come on and stay on)
Old Nov 2, 2006 | 02:15 PM
clarkdr81's Avatar
clarkdr81
You could also do a GP and remove one or both of the rear seats...
Old Nov 2, 2006 | 03:23 PM
tnoy66's Avatar
tnoy66
Under front seats
Under the carpet is a piece of polystyrene, I removed that and fitted a 9mm thick board to screw the amp onto. Then cut the carpet around the amp
The amp fitted there is a Genesis Dual Mono and there's another one under the other seat
It measures 300 x 210 x 62mm (roughly 12 x 8.25 x 2.5 inches)
The attatchment shows the available space which someone else measured
Attached Thumbnails where to put the amp (not killing my trunk)?-styro-insert.jpg
Old Nov 2, 2006 | 03:37 PM
kurvhugr's Avatar
kurvhugr
Here's another example.
Old Nov 3, 2006 | 10:06 AM
MiNi_MaC's Avatar
MiNi_MaC
Thank you Tony66 and Kurvhugr, those look like good places.
Thanks for your cooper-ation everybody.
MaC
Old Nov 3, 2006 | 01:44 PM
shankrabbit's Avatar
shankrabbit
I'm not too sure what kurv's link showed since it won't open for me... but here is another idea.
Make a false floor out of peg board (plus you can customize the paint job like I did)
Old Nov 6, 2006 | 07:37 AM
MiNi_MaC's Avatar
MiNi_MaC
Thank you shankrabbit, but i dont think that will work for me, i wanna save the trunk space (yes yes what espace? ).
MaC
Old Nov 6, 2006 | 07:55 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
MaC
You have a MINI, you dont have 'trunk' space, you have BOOT space
Old Nov 6, 2006 | 08:00 AM
shankrabbit
MaC
Are you planning on putting an aftermarket sub in there too? Or are you just planning to have the amp run new speakers in the current positions?
Old Nov 6, 2006 | 10:10 AM
MiNi_MaC's Avatar
MiNi_MaC
Amp + New speaker
Old Nov 6, 2006 | 02:10 PM
shankrabbit
Amp + New speaker
Ahh.
Well depending how much dismantling you want to do and on the size of your amp, you could put it in the left cubby hole of your boot. (Although this would require removing some paneling and then re-attaching.)
Old Nov 7, 2006 | 05:44 PM
Bugs's Avatar
Bugs
Originally Posted by kurvhugr
ehehe thats my car!
Ive cleaned things up considerably since then, and also, now have an amp under both of my front seats
nice beefy mono block under the driver side, running my 12" sub in the rear, and a 4Channel amp under the passenger seat running the front/rear component sets.
sounds is fabulous. I can remove the sub box inside of 15seconds. with the sub box removed, I have a 100% oem looking interior except for the alpine head unit, which happens to match the interior perfect
Old Nov 8, 2006 | 07:19 AM
MiNi_MaC's Avatar
MiNi_MaC
Originally Posted by Bugs
ehehe thats my car!
Good job ... pics?... hey how did you find those spaces? did you start ripping things off untill you find them?
Old Nov 8, 2006 | 10:40 AM
Bugs's Avatar
Bugs
someone else mentioned the styrofoam under the seat. I put a small slit in the carpet, and found the same thing. Just got lucky
No pics this time. Its essentially the same as my old pics, but with better amps under the seat.
madmax88
Aug 21, 2017 07:07 PM
khumpert
Nov 30, 2015 11:48 AM
DNytAftr
Aug 31, 2015 07:36 AM
D3nZem
Aug 30, 2015 07:05 AM
Lee-Oh_825
Aug 11, 2015 10:27 PM
