Suspension Removing Strut Bolt During Spring Installation
Old Oct 22, 2006 | 07:43 AM
qwertmonkey's Avatar
qwertmonkey
Ok, quick question.
I remember when I was changing the springs on the MCS, I ran into a little pickle. When I was re-installing the strut, I couldn't get the strut bolt to tighten. It would just spin. It was recessed, so I couldn't just use a wrench and an allen to hold it still. I would need an "Open ended socket." Well, my auto parts store had a set for $50, but it it only went up to 19mm or so. I needed, I believe, a 21 or a 22. What I ended up doing was buying a regular socket that would fit around the nut. I stuck the allen in there and had someone yank on the socket with a pipe wrench. I got it plenty tight, but it was VERY difficult. So, I was wondering, what did most of you do? Where can I get an open ended socket set that goes past 20mm? Right now, I have some off brand springs that didn't have a perfect fit. I've had some ALTA's in my garage for almost a year now. Thats a quality part, unlike what is on the front now.
If you have any clues, please let me know!
Thank you!
Oh, also, the pictures on Randt Webb's How-to seem to be broken. Does anyone know if they will be fixed?
Again, thank you,
William
Old Oct 22, 2006 | 09:03 AM
kenchan's Avatar
kenchan
are you talking about the tower bolts or the piston shaft nut?
for the piston shaft nut, i did what i think you described.
used a regular socket, dropped a key in there, turned the
socket with channel-locks.
Originally Posted by qwertmonkey
Ok, quick question.
Thank you!
Again, thank you,
William
Old Oct 22, 2006 | 10:33 AM
qwertmonkey
Piston shaft nut.
Gotch ya. That is what I am talking about. Were you able to get it tight enough? I just didn't know where to find a specialty tool like that. How did most of you other guys do it?
Old Oct 22, 2006 | 03:40 PM
90STX's Avatar
90STX
Same way. No problem getting things tight enough. It also helps to do the final tightening with everything installed and the car sitting on the ground.
Scott
90SM
Old Oct 23, 2006 | 08:14 AM
curv872's Avatar
curv872
Ok, quick question.
Thank you!
Again, thank you,
William
Bought these for the exact same reason!
Harbor Freight
They work great!
Joe
Old Oct 23, 2006 | 10:20 AM
kenchan's Avatar
kenchan
Piston shaft nut.
yep, you don't need to crank it that much. hand tight snug is fine.
If you're worried about it loosening, you can either use new
nylon backed lock nuts or loctite blue.
Old Oct 23, 2006 | 10:22 AM
Motoring's Avatar
Motoring
Impact gun works great.
Old Oct 23, 2006 | 10:41 AM
xizor's Avatar
xizor
did mine yesterday and the impact gun did the trick. that harbor freight set is pretty trick though
Old Oct 23, 2006 | 05:12 PM
qwertmonkey
THANK YOU!
Harbor Freight
They work great!
Joe
Kenchan, I'll still use that method when needed, its just that those tools will make me feel so much better. I'm a little paranoid. :impatient
Thanks for all the tips guys. I'm going to slap some ALTAs on there the on the 5th.
I'll let you know how I like em.
Old Oct 23, 2006 | 06:58 PM
kenchan's Avatar
kenchan
THANK YOU!
use the right tools if you have them handy.
Old Oct 24, 2006 | 03:15 AM
dnjat's Avatar
dnjat
make up a special socket
I took a socket and welded a 3/4" nut on the top of it. That way the allen could fit through the center and a box end wrench went over the 3/4" nut. I ended up making up a few different sizes so the I could also loosen the nuts on the strut bar too. Works great.
Old Oct 24, 2006 | 07:29 AM
qwertmonkey
Now THAT is improvising. Bravo!
Being the cheap person that I am, I think I might do that instead!
Thanks again for all the help, guys.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
squawSkiBum
Oct 2, 2015 09:21 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
minipopkart
Aug 13, 2015 05:22 AM
