No more coolant bottle leaks
Old Apr 12, 2003 | 12:30 PM
vdubdoug's Avatar
vdubdoug
I just ordered the Forge motorsport Coolant bottle
I am tired of going back to the dealer for coolant leaks.
What do you think?
Old Apr 12, 2003 | 12:39 PM
Nobull60's Avatar
Nobull60
How will it adapt and is the capacity the same as the stock??
Old Apr 12, 2003 | 12:49 PM
vdubdoug's Avatar
vdubdoug
Forge says it is a direct fit. And as long as it holds the same amount of coolant (or close to it all will be ok). I am used to running low anyway since my present plastic bottle is leaking all the time.
Old Apr 12, 2003 | 01:00 PM
Moorlockx's Avatar
Moorlockx
Rather pricey little jewel there, isn't it?
Old Apr 12, 2003 | 01:18 PM
vdubdoug's Avatar
vdubdoug
150 bucks or many trips to the dealer to wait 2 hours for them to replace the bottle.
Old Apr 12, 2003 | 01:50 PM
MG-BGT's Avatar
MG-BGT
very cool tank!
Could you post a link to the mfg or retailer please? TIA!
Also, do you know whether this tank has the same internal baffles as the OEM MINI tank? Was this made specifically for MINIs?
Great post, thanks!
Cheers,
Markus
Old Apr 12, 2003 | 02:37 PM
8ball's Avatar
8ball
>>very cool tank!
http://www.forgemotorsport.com/mini.asp?cat=mini
Old Apr 12, 2003 | 02:46 PM
kumquat78's Avatar
kumquat78
Warning stupid, I know nothing about motoring question.....
Any concerns about heat and it being metal??
Please don't yell at me!!
Old Apr 12, 2003 | 02:51 PM
8ball's Avatar
8ball
Hello, Kumquat! and welcome to MCO! ...
the tank would get a bit hot but you probably aren't going to touching it often - paint it 'safety yellow' if you are worried ...
... and the fact that metal will dissapate the heat better than the plastic tank means that, if anything, it will provide a source of cooler coolant for the engine ...
Old Apr 13, 2003 | 02:24 PM
Moorlockx's Avatar
Moorlockx
Just curious. I don't know what year you car is. I'm assuming it's an '02 since you've been with MCO since Aug of '02. Did your dealer try to upgrade you to one of the new style tanks? or is that not possible? I'm not picking with you. In fact, if I had the tank problems as bad as some of the folks on here have had, I'd probably be going the same route....not to mention the Forge looks pretty good. :smile:
Old Apr 13, 2003 | 02:31 PM
vdubdoug's Avatar
vdubdoug
yeah I got the latest and greatest tank 2 months ago. It just recently started to leak.
Old Apr 15, 2003 | 09:47 AM
vdubdoug's Avatar
vdubdoug
I just got an Email from Forge Motorsport. they stated that the bottle is a direct fit and it has a coolant level window. They are currently out of stock and i should have my bottle shipped in about 3 weeks. :smile:
Old Apr 18, 2003 | 01:01 PM
MGCMAN's Avatar
MGCMAN
vdubdoug,
Keep us in the know with the Forge tank. Maybe even a pic once its installed. I agree, $150 is well spent if it permanently cures the leaks. In the meantime, does Depends make anything to fit the MINI?
Old May 15, 2003 | 02:29 AM
borealis75's Avatar
borealis75
hi,
did you have fitted your new coolant tank? does it fit well and wat are your first impressions?
Old May 15, 2003 | 06:10 AM
Trippy's Avatar
Trippy
Does anyone know WHY the MCS coolant overflow bottle
is pressurised and the Cooper is not?
BOTH cooling systems are pressurised, but they made the
overflow bottle also pressurised on the MCS, and that seems
to have been a bad decision.
I can't see how it would make any difference in the cooling
capacity of the system, so why did they do it that way?
Oh, hey, I just thought of something...
Is it possible that the cooling loop in the engine gets much
higher in the air than the Cooper, and they couldn't find a place
in the engine compartment that is higher then the coolant
loop to put the bottle?
Old May 15, 2003 | 07:21 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Looks like you can wash clothes in that metal tank :evil:
Old May 15, 2003 | 04:35 PM
Ethos's Avatar
Ethos
Very cool. Please keep us posted after you get this. I was planning to buy one myself--recently bought a strut tower brace from Forge--but decided against it bc of all the coolant problems described on MCO. My thinking was that the problems with the factory coolant overflow tank might actually be WORSE with this new tank since the overflow tank is no longer "the weakest link" in the coolant overflow system. Eg, I'm worried that instead of the tank leaking, a pressure imbalance in the system might eventually cause a hose failure or something more serious.
I'd be interested in hearing from anyone who's more knowledgeable about this if this is an legitimate concern.
Also, does the tank come with a cap?
thanks.
Old May 18, 2003 | 11:44 AM
Yucca Patrol's Avatar
Yucca Patrol
That new metal tank look pretty cool and I am sure it won't leak, but I think that it is a bit of engineering overkill to fix a simple problem.
I had my leaking tank replaced with the newer part and have had no leaks since.
Anyway, I still would like to see it on someone else's MINI. That metal can is sure pretty!
Old May 19, 2003 | 06:20 AM
Humourless's Avatar
Humourless
Stupid question time: How does one check the level with a tank like that?
-CW
Old May 20, 2003 | 03:37 PM
2minis's Avatar
2minis
>>-CW
Smart answer. Coolant level window as stated above....
Old May 20, 2003 | 05:37 PM
Humourless's Avatar
Humourless
>>>>-CW
Reading comprehension > me.
ops:
-CW
Old Jun 3, 2003 | 11:56 PM
jonathanks's Avatar
jonathanks
The cooling system has a working pressure and a relief pressure. If the system overpressurizes the relief dump on the cap will be overcome and the coolant should evacuate without any component damage. Therefore the Forge tank should have no effects on the remaining system.
It appears that the real issue with the bottle is not the pressure but the manufacturing method employed. If it leaks around the seams consistently, then it is probably not a material defect, otherwise the tanks would be failing at high stress points within the pressure vessel, i.e. at places where the curves are the sharpest. But a manufacturing process flaw where the injection mold process is performed could cause a non homogeneous mate at the mold seam, could be the speed i of injection, fluid plastic temperature, etc. My guess is that the engineers working on this are trying to change the manufacturing process method with the newer tanks rather than design new ones that require tooling changes in the plant where they are made. Unfortunately, it loks like the long production run solutipon has not been found yet.
Not saying that all is well in wonderland, just offering a possible reasoning behind an all out design change...
patsum
26
May 29, 2021 06:29 PM
shorenetworks
Nov 4, 2019 06:18 PM
sempaipaul
Oct 26, 2015 05:56 PM
debitsandcredits
Sep 21, 2015 08:34 AM
makg
Sep 10, 2015 11:59 AM
