Suspension Help - bad pull to the right!
Old Oct 12, 2006 | 08:03 PM
pure&simple's Avatar
pure&simple
Dealer replaces driver's side front xenon headlight self-leveling sensor. To do this, they needed to remove to the driver's side axle. I pickup the car and it now pulls HARD to the right whenever I step on the gas. They re-align it to OEM spec. It still pulls HARD to the right. I don't believe it has anything to do with the alignment. What could be causign the problem? A bad limited slip diff? Is it possible that an axle is misaligned? Help a brother out... any suggestions?
Old Oct 12, 2006 | 11:25 PM
Jtrem's Avatar
Jtrem
sounds like the axle could be misaligned. Take it back to the dealer and explain what is happening. That could be a hazzard.
Old Oct 31, 2006 | 03:12 PM
pure&simple
One part of the problem was related to the installation of powerflex front control arm bushings. That part has been resolved, but the pull is only 50% gone. It is most noticeable on the highway when you're coasting along and then get on the gas about 1/4-1/3 throttle to pass someone or protect your position. The car pulls to the right at 3200 rpm under light throttle. When you get off the gas, the pull stops. At that rpm and throttle position, it can't be torque steer can it?
My only theory at this point is that it had something to do with the way the axle was put back into the OEM limited slip diff. Perhaps one wheel is getting more power than the other? Maybe something is misaligned? I'm looking for suggestions at this point...
Filmy
Apr 28, 2019 11:37 AM
dube53
R58 :: Coupé Talk (2012+)
Sep 11, 2015 09:30 AM
Sc00terbum
Sep 11, 2015 07:17 AM
larryd96
11
Sep 8, 2015 05:01 AM
Filmy
Sep 7, 2015 08:27 PM
