Suspension bushing grease
Old Oct 5, 2006 | 08:39 PM
RIPPER's Avatar
RIPPER
bushing grease
I have an h-sport rear swaybar with the zerk fittings and I need to grease them. Does anyone now where I can get a grease gun to fit the nipples and what type of grease I need
Old Oct 6, 2006 | 08:40 PM
ekim's Avatar
ekim
A standard hand grease gun with a tube of synthetic grease will work.
Old Oct 11, 2006 | 10:49 PM
Nitro22's Avatar
Nitro22
I suggest this grease:
You can get the grease gun at most local auto parts stores.
Lucas X-tra Heavy Duty Grease
http://www.lucasoil.com/products/dis...tid=2&loc=show
You can find it at Original Parts Group's website.
Old Oct 11, 2006 | 10:58 PM
chrisneal's Avatar
chrisneal
Is there a how-to on this somewhere? I was told that my swaybar wouldn't squeak, but it does. I know where the bushings are, but I don't know exactly where to direct the grease.
Old Oct 12, 2006 | 01:32 AM
Nitro22's Avatar
Nitro22
If your rear sway bar bushing brackets have 90degree zerk fittings they would be located right above the bracket. Just use a grease gun and inject the grease into the fitting until you start to see the grease ooze out.
Good Luck!
Old May 2, 2007 | 03:34 PM
latte hiatus's Avatar
latte hiatus
Sorry if this is a dumb question: Is this grease gun coupler in the photograph what y'all use to mate up to the zerk fitting? Or is there a special zerk adapter that I need? Thanks in advance!
Old May 2, 2007 | 07:22 PM
kapps's Avatar
kapps
Yeah, that coupler will snap into the zerk. I haven't found an easy way to get the coupler off the zerk when you're done, though.
Honestly, I'm not really sure the zerk does much. When I did mine, all the grease leaked out between the mount and the bushing instead of between the swaybar and the bushing. To really re-grease it, you need to remove the mount and put the grease on by hand.
Old May 2, 2007 | 08:41 PM
TonyB's Avatar
TonyB
I'm a little bummed as the zerks have let me on two previous attempts. It is for this reason that I started this thread:
https://www.northamericanmotoring.co...ad.php?t=98289
That said, I'm going to try using a grease gun again this weekend, and might even get the above recommended Lucas grease...
Old May 2, 2007 | 10:30 PM
latte hiatus
Some people would say that the definition of insanity is repeating the same procedure over and over again, expecting a different result.
I'm not one of those people. Hope the Lucas grease and the grease gun works out!
Old May 2, 2007 | 10:32 PM
latte hiatus
Thanks, kapps - I'm going to try it out this weekend. I had the hardest time finding the coupler last week when I needed it, so trying to get grease into the zerk fitting didn't work out very well. I'm glad I didn't go to the local auto store to ask for a zerk coupler - thank goodness for NAM!
The polyurethane mounts can be loosened to re-grease without removing the entire sway bar, correct? Any lithium grease should be fine (won't corrode the polyurethane)?
Old May 2, 2007 | 11:02 PM
TonyB's Avatar
TonyB
Heck, I'll probably get frustrated that the zerks are not cooperating, and just loosen the brackets and try to shoove-in some grease... This is one of the main reasons I got this bar. Oh well...
Edit/Add: Decided to tackle this today (Fri), and once again utilization of the Zerk fittings did not work as the lube gushed-out between the bracket and bushing, not bar and bushing. I removed the brackets and bushings, lubed them, and re-installed. I cleared-out the passageway in the bushing hoping that might have been the culprit, I tried again afterwards, and the brackets still oozed lube. Drat.
YaTuSabe
Aug 23, 2018 11:41 AM
OutMotoring
Mar 3, 2017 06:29 AM
bahman
Feb 14, 2016 10:29 AM
pahg
Oct 5, 2015 11:50 AM
rt808
Sep 29, 2015 03:15 PM
