Suspension The Skinny on H&R's sportcoilover ride height
Old May 2, 2007 | 12:49 PM
meb's Avatar
meb
In another thread from a far distant galaxy...we were discussing H&R ride height. Apparently, and many phone calls later, H&R offer a number of different springs lengths for the Sport coilover kit. If you do not like the height of the 'stock' kit, you can order a spring that is identical in rate but 1,2,3...inches longer. I was informed that other spring rates are available too, but I ran out of energy before confirming this.
H&R are out of stock and there is no ETA. I was told to call back in four weeks. I have no part numbers to share at this time.
As I wrote in my other thread, the ride height is a tad too low for me - another 1/4" would be great! The difficulty here is that the front spring is a true progressive rate spring. So as we raise ride height, the spring is compressed fairly far into its progressive range.
You cannot order the kit with different springs - it comes with one spring length and one spring length only. The additional springs are about $70.00 each +/-. you can order the springs from whom ever your kit was ordered.
Another 1/4" in ride height and two more inches of spring travel This in no way should be taken as knocking H&R. Plenty of folks love the ride height and some like it lower . But H&R realize that a few Mini folks have complained and they have responded for us few Even with the cost of the extra springs, this kit is very nice! Zero regrets.
Old May 2, 2007 | 04:36 PM
chilirojo's Avatar
chilirojo
that may be a good option... good to know. I may try that too...
maybe a question for the experts; swapping in a longer spring (or a stiffer rate) will raise ride height... but, wont this also make the wheel/tire/suspension unload too readily, i.e.; riding around with the damper closer to full extension???
Old May 3, 2007 | 05:35 AM
meb's Avatar
meb
Within reason, no. The spring should be an inch or two longer at the same ride height. If a spring is compressed too far it will reach block height and bind. Think of the damper's stroke and then imagine moving a spring up and down the damper's stroke. Where the spring sits ultimately determine where its optimum range is too...but the difficulty here is that a progressive rate spring acts progressively when being compressed to achieve ride height. Whereas a linear spring doesn't care about anything but block height - affected by rate and length. Once the progressive range is used up, a progressive rate spring becomes linear...but there are lots of spring types out there.
H&R will have this figured out for sure! You can comfortably go with a spring two inches longer.
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
pkillur
Sep 30, 2015 10:51 AM
Emnotek
Sep 29, 2015 07:37 AM
gnhovis
Sep 28, 2015 10:56 AM
