Suspension change to new nuts when installing strut bar?
Old Oct 3, 2006 | 03:02 AM
dandman's Avatar
dandman
hi
i bought a dinan strut bar used for my 03 cooper s. can i use the original nuts that are on the strut tower, or do they need to be replaced with new ones?
thanks
dan
Old Oct 3, 2006 | 04:04 AM
norm03s's Avatar
norm03s
Bentley say's to replace self locking nuts. Don't overtighten those nuts when installing them. Torque spec = 25 ft. lb.
Old Oct 3, 2006 | 02:24 PM
MiniKJ's Avatar
MiniKJ
Just want to confirm, the OEM nuts are self-locking, right?
Old Oct 3, 2006 | 02:26 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Yes, and replacing them with same, or similar (my IE camber plates came with nuts and lock washers) is a good idea, I think.
Old Oct 3, 2006 | 04:11 PM
UKSUV's Avatar
UKSUV
I reused mine. Just make sure you torque them down properly.
Old Oct 3, 2006 | 04:15 PM
Crashton's Avatar
Crashton
I see absolutely no reason those nuts should be changed when installing a strut bar. If you are worried about it go ahead & change them or hit them with a bit of blue Locktite. My strut bar has been on there for 9,500 miles using the original nuts with no problems.
Old Oct 3, 2006 | 06:13 PM
CHKMINI's Avatar
CHKMINI
I agree! I reused the original nuts 20,000+ miles ago. I've checked the torgue several times with no lossening at all.
Old Oct 3, 2006 | 07:40 PM
kenchan's Avatar
kenchan
at only 25lbs/ft, i reused mine.
you can put a dab of thread-lock if you're worried. i didn't put anything
on mine.
squawSkiBum
Oct 2, 2015 09:21 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
sprp85
Aug 22, 2015 06:16 AM
nomar116
Aug 10, 2015 11:24 PM
