Suspension NEX Coilovers
Old Sep 29, 2006 | 07:36 PM
ChesterVT's Avatar
ChesterVT
NEX Coilovers
Nex Coilovers are priced very cheap at mini mania . Are they OK and does anyone have any experience with these. Almost half of most coilovers.
Old Oct 16, 2006 | 01:21 PM
Smokey's Avatar
Smokey
Anyone?
Old Oct 16, 2006 | 01:40 PM
scobib's Avatar
scobib
They look a lot like the Megans, just in a different color... Shrug.
Old Oct 16, 2006 | 01:44 PM
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
I would bet they are the same products (Megan/NEX/Etc.) being made in China and rebadged as whatever name anyone wants.....that seems to be the case with most of the lower priced coilovers....
Old Oct 16, 2006 | 02:17 PM
Smokey's Avatar
Smokey
Thanks - noticed them on a few sites but hadn't heard much from the MINI crowd about them.
One more ? for you: With these adjustable coilovers, for basic driving are you counting threads exposed to determine if the height is the same or what?
Old Oct 16, 2006 | 04:57 PM
ChesterVT's Avatar
ChesterVT
Thanks,
I think I will stick with the Koni's, H&R, or Bilsteins.
Old Oct 17, 2006 | 01:40 AM
brownflyer's Avatar
brownflyer
No, these are not Megans. Megans (and similar coilovers) use an adjustable front camber plate as part of the upper spring perch. This is how you can tell if they come from same manufacturer. Nex re-uses the stock spring perch for the front suspension. Also, the Nex front springs have different spring circumference from top to bottom whereas the megans have same from top to bottom.
This kit actually looks more like the PSS9.
Interesting, the more I look at them, it seems to be a designed half way between the PSS9 and Megans. Where the Nex have full ride heigth adjustability w/o loss of damper travel but no camber plates or adjustable dampers. As with the PSS9 if you adjust the heigth, you loose damper travel. I'm kind of liking the design as they kept the front springs similar to stock.
Anybody out there running on them???
Old Oct 17, 2006 | 01:52 AM
Smokey's Avatar
Smokey
x2
A pic of the normal kit
Old Jul 31, 2007 | 06:20 PM
jeffc's Avatar
jeffc
7th Gear
Anyone running these? Anyone have pictures, reviews or comments on these?
Old Aug 12, 2007 | 03:05 PM
Wake|MCS's Avatar
Wake|MCS
BUMP, anyone running these? The price is very enticing...
Old Sep 11, 2007 | 11:33 PM
ninjlao's Avatar
ninjlao
Ninja Mini
I just wanted to note about the straight springs are more geared for racing because they are not progressive.
What I like about coilovers is all of there adjustability. With straight springs you can buy new springs from better spring manufacturers (all you need is the inner diameter and length). These coilover companies may make good shocks but the springs most definately sucks.
Whenever I buy coilovers for any of my cars, I buy new springs from a company called SWIFT. Here is my philosophy- Europe makes awesome shocks (moton, quantom, bilstein)
Japan makes the best springs- they are the best in the world in metalurgy.
anyways That is why I prefer the straight springs.
Old Sep 12, 2007 | 11:05 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
nm
RIchard Nguyen
Sep 14, 2016 11:43 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
sssevita
Mar 20, 2016 06:24 AM
CooperSharp
Oct 12, 2015 09:21 AM
gnhovis
Sep 28, 2015 10:56 AM
