R50/53 How do you clean front grill without removing chrome?
Old Sep 24, 2006 | 11:17 PM
dix's Avatar
dix
We've had an abundant crop of grasshoppers and other large assorted bugs this year and after picking their mashed and mangled bodies off of my grill, I'm at a loss for finding anything that might help clean it totally of the dried bug guts. I've tried using a soft toothbrush and soapy water but there has to be a way to clean it better. Any suggestions? I'm getting bad knees from constant kneeling to clean the darn thing.
Old Sep 25, 2006 | 03:39 AM
davavd's Avatar
davavd
If you search "love bugs", you'll find a thread I started recently. I didn't get much of a response, but one guy recommended Griot's Bug-off, which is supposed to make them not stick so hard. I haven't tried it yet.
Old Sep 25, 2006 | 05:01 AM
Red Ryder's Avatar
Red Ryder
Coordinator :: Tar Heel MINI Motoring Club
I have never tried this, but you might try a hair dryer. Heating it would bring them to their "natural state" and might make it easier. I have used a hair dryer to remove dried glue and other items.
If it doesn't work then at least they will look better.
Old Sep 25, 2006 | 05:04 AM
erickvonzipper's Avatar
erickvonzipper
You can also use the old time tested method of removing bugs from motorcycle plastic windshields. Soak a (100% cotton) towel in hot water and lay it over the affected area (wedge it into the grill slats a bit to get it all). Leave it there a few minutes. The heat and moisture loosen it all up so it can be wiped away or rinsed off.
Old Sep 25, 2006 | 07:13 AM
creseida's Avatar
creseida
murphys oil soap, available in the laundry or cleaning supplies area at your local grocery. softens the critters up. 95% of them just hose right off.
Old Sep 25, 2006 | 04:44 PM
Little bit's Avatar
Little bit
The Mr. Clean Magic Eraser works wonders.
Old Sep 25, 2006 | 09:20 PM
Donna/Mike's Avatar
Donna/Mike
Sand Dollar Collector
Ditto! Those things are AWESOME....for cleaning everything...well almost everything... But of course, read the directions for things you shouldn't use them on...
Donna
Old Sep 26, 2006 | 03:55 PM
jclayto's Avatar
jclayto
I agree.... The Mr Clean eraser is the only thing i could find to do the trick
Old Sep 26, 2006 | 04:10 PM
Grassroots Garage's Avatar
Grassroots Garage
I've always had good luck with good old ammonia glass cleaner and a soft rag. This was my method of choice when working on Rolls and Bentleys, should be good enough for a mere MINI
Old Sep 26, 2006 | 09:39 PM
dix's Avatar
dix
Thanks so much for the helpful suggestions! I intend to try each one to see which I prefer.
Old Sep 26, 2006 | 10:32 PM
El_Jefe's Avatar
El_Jefe
the hot water and rag is best/safest and a great idea! Chrome is real chrome and can pitt. I would wonder about a strong base on chrome?
after you do that, I would use either MEguiar's line of chrome polish or Griot's.
Old Sep 27, 2006 | 09:55 AM
Crusoe's Avatar
Crusoe
Build a bird cage that mounts on the grill, blocks the radiator fins and intake hole off and stock it with a few hungry tweeties. You'll have clean grill and radiator in no time.
Old Sep 27, 2006 | 02:24 PM
HighSchoolzMINI's Avatar
HighSchoolzMINI
It better be!
Old Sep 27, 2006 | 02:55 PM
DaveTinNY's Avatar
DaveTinNY
Also, for ergonomics and less sore knees, OPEN the bonnet. Makes it VERY easy to get to the bottoms of the grills. :-) Also gives reason to clean off the various engine areas.
Old Oct 1, 2006 | 04:56 PM
HighSchoolzMINI
Have you ever tried picking bugs out of the intercooler and radiator after a 1400 mile road trip, lol that was the best
I even used tweezers
boostedhaze
Jan 2, 2018 07:26 PM
wkp1219
Nov 13, 2015 07:52 AM
dcrna1
Aug 19, 2015 01:30 PM
FLYM1N1
Aug 15, 2015 11:20 AM
penguinhomey
Aug 14, 2015 09:05 AM
