R50/53 Steering wheel shake
Old Sep 20, 2006 | 11:34 AM
Minihed's Avatar
Minihed
Our '03 MCS has a shimmy/shake in the steering wheel from around 20mph to 50mph. the shake varies in intensity, never is it real bad, but it is definitely there. I had new tires put on, balanced and aligned. While this reduced the issue it did not eliminate it. My theory is a rim may be warped or out of whack. If it's not that, what else could it be. Any ideas?
Old Sep 20, 2006 | 11:40 AM
Jenn B's Avatar
Jenn B
Do you have stock wheels?
Hubcentric rings are a must if not.
Old Sep 20, 2006 | 12:04 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Check this thread...
https://www.northamericanmotoring.co...ad.php?t=73735
it might be what your car is doing.
Old Sep 20, 2006 | 01:44 PM
Minihed's Avatar
Minihed
Yep, that is exactly what my car is doing. But nothing seems to work on the problem. I'll check the air pressure and see if that does the trick. If not I'll have to take it to the dealer (110 miles away). I have the stock rims.
Old Sep 20, 2006 | 02:21 PM
C4's Avatar
C4
You could have a bent wheel rim or something else may be damaged in the suspension.
Have you hit any huge potholes?
Old Sep 20, 2006 | 05:07 PM
MGCMAN's Avatar
MGCMAN
Have a local tire shop balance your wheels, methinks one may be unbalanced, giving you the shimmy. Remember to retorque to 90 lb.ft
Old Sep 20, 2006 | 05:13 PM
kenchan's Avatar
kenchan
best would be to swap the wheels/tires with your spare if you have
a set and compare.
otherwise, i would put the front ones on the rear and see if that
helps. if yes, your front needs to be rebalanced.
Old Sep 21, 2006 | 07:11 PM
minimitch06's Avatar
minimitch06
hey i just got 18s put on it and it does the same thing as u ...i no its so wierd but its beacuse of the low profile tires
write me bak
Old Sep 21, 2006 | 08:28 PM
princeofwaldo's Avatar
princeofwaldo
My vote is bad wheel hub on front drivers side. Second vote bad hub on passenger side. Was probably okay until you took weight of car off the hub to change tire/wheels. ie failed like a water pump after belt tension is removed... you get the idea... Can probably make the symptoms go away for a while but ultimately there is a bad part in the front end, hub, tie rod etc. Especially if more than 50k miles on the car.
Manny_cooper
Sep 10, 2015 11:09 AM
mdarreen
Sep 2, 2015 10:11 AM
trw92a
Aug 26, 2015 01:47 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
