Solo Jack Stands
Jack Stands
Mitchman brought this up in another forum, but I figured I'd ask here since a lot of guy swap all four tires at events.
Where's the best place to put the jack stands under a Mini to have all four wheels off the ground?
In six years of autocrossing, I've never needed to get all four corners off the ground on the site at one time. I don't even bother with jackstands, because I don't get under the car when changing tires, and I always jack on level ground.
-Keith
-Keith
Ok, I don't think that the question has been answered.
I have had the car on four jack stands a couple of times. Each time, I took a two by four about 1-2 feet long, lined it up with the "frame rail" that runs just inside of the jacking pucks, and that is where I jacked it (the two by four spreads the load along the "rail"). I made sure was far enough back to allow jack stands to fit once it was jacked up. I put the jack stands under the jacking pucks. Then I just went to the other side and did the same thing. I must say that I was always concerned about the side that was on jack stands while I was jacking the other side up, worried that a jacking puck would break off, but fortunately it never happened. I also had a jack on both sides as a back-up in case something happened.
Jake
Jake
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
