Small Portable Aquaeous sort of Vacuums?
Old Sep 6, 2006 | 04:08 PM
El_Jefe's Avatar
El_Jefe
Are there any small vacuums that enjoy sucking up water along with dirt? The biggest bane to washing a car on LongIsland is the humidity that prevents a cars sills and cracks from ever drying out. I just cleaned and waxed a car of my friends and later on that day streaks of water dried on the wax as he drove off
Old Sep 6, 2006 | 07:04 PM
kenchan's Avatar
kenchan
i use a cordless leafblower.
Old Sep 6, 2006 | 07:24 PM
MiniMaybee's Avatar
MiniMaybee
Blow, don't suck ! If you use the vacuum chances are you will suck the nozzle onto you paint - scratch potential high. I use either my leaf blower or my air compressor for all the naughty bits (water holding cracks).
Chuck
Old Sep 6, 2006 | 07:25 PM
jwardell's Avatar
jwardell
A small wet/dry vac would do it well...we discussed them recently here:
https://www.northamericanmotoring.co...ad.php?t=76488
Old Sep 6, 2006 | 08:46 PM
El_Jefe's Avatar
El_Jefe
thanx!
that thread went to hell though. It started out decent though. Is the 30 dollar job from sears good enough for vacuuming dried in dirt in carpet of a mini? theres a bump up with more hp, but I would think 1.5 is fine enough? hm.
Old Sep 6, 2006 | 08:57 PM
agranger's Avatar
agranger
A Searsh $30 special would be fine for random auto vacuuming... check the detailing 101 threads, there was a discussion about shop vacs just a week or so ago.
I'd also recommend against vacuuming the water off of the paintwork. I think you would be better off w/ a leaf blower or an air compressor... or just some microfibers for drying. You might also look into the Mr. Clean Spotfree Rinse gadget that sells in Targets for $20-$30... it's supposed to be great for the dripping problem you describe above.
Old Sep 6, 2006 | 09:07 PM
El_Jefe's Avatar
El_Jefe
Yeah I read it. thanks much.
im looking for bottom line. I could always adhere some fabric to the nozzle. I just want something that is going to vacuum the carpet clean as well as pull water out. The water additive I am not to keen on but I hear it works well.
I will ahve to see maybe demo the 1.5 for suction if they let me. I will only be using it for the car. Would be nice to get it all in one without spending 160 dollars on some fancy high velocity guy from griots or autopia
Old Sep 7, 2006 | 05:46 AM
jwardell's Avatar
jwardell
I have the small sears one and it works great. Often goes on sale for $25 and $20.
Old Sep 7, 2006 | 07:15 AM
SumWon's Avatar
SumWon
I would think that blowing the water only pushes it into other places where it doesn't belong, like maybe under seals to start rust? Using a vac to actually remove the water from the vehicle sounds like a much better idea. I agree that the chances of scratching the paint is higher with a vac, but if the person is taking that much care in detailing the car to even worry about this, I would assume they would extend the same care to using the vac.
Old Sep 7, 2006 | 07:43 AM
agranger's Avatar
agranger
Maybe you could wrap 3-4 layers of duct-tape around the business end of the hose... This would help prevent scratches from the hard plastic.
Old Sep 7, 2006 | 10:13 PM
El_Jefe's Avatar
El_Jefe
yes. there are solid methods for handling the scratch possibility. I was doing to adhere felt to the tip.
Old Sep 8, 2006 | 11:13 AM
kenchan's Avatar
kenchan
yeh, then your felt picksup debris and you rub that on your car?
no~~ blow the water out, not suck it in. keep the door open,
run a dehumidifier in the garage for a few hours and a large fan.
that's wat i do.
Old Sep 8, 2006 | 02:47 PM
El_Jefe's Avatar
El_Jefe
It is on average above 80% humidity on long island where I live. Not a special day for that just normal. A very dry day is 40% and that lasts about 12 hours.
im going to suck on my car till its dry and not blow it off.
I feel either method can make a mini happy.
patsum
Sep 15, 2015 09:14 PM
Racingguy04
Electrical
Sep 15, 2015 06:19 AM
potterstein
Sep 13, 2015 09:57 PM
potterstein
Sep 11, 2015 09:24 PM
Sep 11, 2015 11:09 AM
