R52 Cabrio dome light questions...
Old Sep 3, 2006 | 10:26 AM
ImagoX's Avatar
ImagoX
1. How the heck do you remove the dome light cover so you can access the dome light bulb? I tried using a PC flathead screwdriver to pop it off and I can't get it up in there.
2. Does anyone know what the bulb in there is? It's round and it LOOKS like the same bulb as is used in the map lights, but without removing them it's hard to tell.
3. Does anyone know if the map light bulbs are the same in the cabrio as they are in the hard top? I need to know so I can replace them with high-intensity LED replacements (if possible). Also, how the heck do you get 'em out?
4. There are two pop-off vents on each side of the rear-view mirror post, but I can't feel anything up there when I remove them... Is there something up in there that releases the light assembly or light cover perhaps?
Old Sep 3, 2006 | 11:03 AM
ThomB's Avatar
ThomB
The entire light assembly just snaps down. You have to give it a good tug, but it'll all just drop.
Old Sep 3, 2006 | 06:04 PM
mini-rolls's Avatar
mini-rolls
THis is what the light assembly like looks like when removed.
Old Sep 4, 2006 | 09:40 AM
ImagoX's Avatar
ImagoX
Where did you get a grip on it? Also, Mini-rolls, that pic - are those metal clips on the FRONT or the REAR of the assembly? Lokks like the FRONT edge to me.
Thanks!
Old Sep 4, 2006 | 10:37 AM
mini-rolls's Avatar
mini-rolls
Back edge, small screwdriver to pry it down. be gently.
Old Sep 4, 2006 | 11:32 AM
bamatt's Avatar
bamatt
It took me a year to even notice that there was a center light in my cabrio. I always thought it was awfully dark in there at night when I opened the door . It has never worked, only my side maplights have. I guess if replacing the bulb involves taking the whole lighting assembly down I will just have to wait til my next trek to the dealer.
Old Sep 4, 2006 | 10:16 PM
ImagoX's Avatar
ImagoX
I must be doing something wrong... I can't get it off and I feel like I'm forcing it. Did you pry from the edge close tot he windsheild or on the ede facing into the car? When prying against the edge facing into the car, I can't get it to drop down.
Is there something behind the two removable vents on either side of the rear-view mirror stalk that releases the panel? I felt around in there but could not figure it out...
Old Sep 4, 2006 | 11:36 PM
MINIBee's Avatar
MINIBee
I'm hoping you're ging to figure this out because there is a small, dead moth trapped inside my dome light and I can't figure out how I can get it out. It's driving me nuts!
Old Sep 5, 2006 | 06:21 AM
schulzmc's Avatar
schulzmc
I've had mine out a couple of times to replace the roof antenna (long story...).
The two metal clips shown in the picture are in the front (the edge facing into the car). There are two plastic edges that fit into slots in the back (the side facint the windshield). It is designed to have the back edges go in first, and then the front (with the flexibile metal clips) snaps up into place.
So you would think the best way is to remove the front edge first, right? I tried and tried and could not remove mine that way. It's a VERY tight fit. I even left strips of duct tape on the front so they hung out when I put the assembly back in once (so I could take it back out that way the next day) and I couldn't get the front edge to budge.
What works for me is to take the back edge (again, the edge toward the windshield) out first. Carefully use a screwdriver covered with tape to pry on that edge, working it back and forth along the slot, and eventually you will be able to pop it down. The good thing about this approach is, even if you gouge up the back edge of the assembly a little it is not visible when you put the assembly back in place.
Hope that helps.
Mark S
Old Sep 5, 2006 | 06:24 AM
schulzmc's Avatar
schulzmc
Oh - and disconnect the rearview mirror first - it makes it easier to get at the back of the assembly. Just give the mirror mount post a firm twist (about 1/3 a turn) and it drops right down.
Mark S
Old Sep 5, 2006 | 07:42 AM
mini-rolls's Avatar
mini-rolls
Many people say front as I look at it, but from a car view the front of the light is to the front of the MINI (i.e. - windshield) The springs clips are on the back side towards the open side of the arch with the top down. The space between the light and the frame is very tight, and it does take some force to pop it down.
Old Sep 5, 2006 | 08:15 AM
ImagoX's Avatar
ImagoX
Hope that helps.
Mark S
Yes, that helps a LOT - thanks!
Old Sep 5, 2006 | 12:17 PM
jbarwilson's Avatar
jbarwilson
Somehow I got the clips all bent out of shape taking the unit out from that edge. Now it will not stay up when I replace it..
So I would suggest that you only try to pry it out from the edge nearest the windshield. I noticed that the tabs there are slightly angled upwards.
Old Sep 17, 2006 | 02:33 PM
PuppetMaster2u's Avatar
PuppetMaster2u
Don't pry it out @ all - - I've posted a How-To in the "Colored LED" thread. Piece of cake.
Old Sep 17, 2006 | 02:59 PM
pjschaffer's Avatar
pjschaffer
Here is a link to PuppetMaster's "How To". good idea removing the "vent thingy" to remove the dome light assembly.
Old Sep 18, 2006 | 11:51 AM
PuppetMaster2u
MINI Bee - Once you have the dome light pulled down, unattach it from the wires so you can remove the center light bulb and either (a) shake the moth out of the hole LOL or (2) unscrew the 2 screws that hold on the facing on.
I just replaced my white bulbs w/ orange LEDs from AutoLumination - I'll post pictures in the Colored LEDs thread.
Old Sep 18, 2006 | 11:55 AM
ImagoX's Avatar
ImagoX
Ooooohh... can't wait! Hope you took shots of the door sill lights too!
Old Sep 18, 2006 | 12:15 PM
PuppetMaster2u
...yeah... I did all 5 of em. The dome light turned out the best of the 5 - though it's not 100% the exact same color, it'd close enough
The others though were/are pretty dim & mesh/grid looking b/c the cover/holder for them isn't clear, like the dome light.. it's kind of white-ish; and it has a sort of grid look to it that projects to the floor. I may take the covers off and dremel out a bit of it to get rid of the grid look, and to allow more light down there. I'll definately post pics though tonight on the colored LED thread.
Lastly.... the 5LED light wouldn't fit thru the hole & I couldn't figure out how to get it in there once I inserted the 5LED bulb in the holder... so I started dremeling it for about 30 seconds until I thought to myself "there's gotta be a better way?" So I stopped, paused and looked it over again...when I saw the 2 screws holding the face on . LOL
Old Sep 18, 2006 | 04:48 PM
PuppetMaster2u
Posted the end result photos in the "Colored LED Dome Lights" thread.
DixonL2
Apr 13, 2021 08:05 AM
ebowling
90
Aug 4, 2019 09:15 AM
WayMotorWorks
Aug 19, 2015 08:04 PM
Aug 19, 2015 12:51 PM
Cal45fan
Aug 11, 2015 03:50 PM
