205/45/17 or 215/45/17 ??
Old Aug 30, 2006 | 06:38 AM
solberg's Avatar
solberg
I'll be getting R99's next week (replacing OE V-Spokes) and will be putting on Toyo Proxes 4. For a daily driver, I was wondering if there is any downside to going with the 215's over the 205's. It seems the price is a little lower, should have better grip, will fill the wheel well a little better, and should give a little more rim protection. I assume there will not be any rubbing issues on the stock suspension, right? Any input would be welcomed. I don't want to regret my decision. Thanks
Old Aug 30, 2006 | 07:29 AM
Dr Obnxs's Avatar
Dr Obnxs
I've done both...
the 215s are a bit nicer for ride and rim protection, the 205s are a bit crisper in turn in. But these can be effected by pressure and lots of other stuff. Either way, you'll be fine. For street and comfort, go with the 215s...
Matt
Old Aug 30, 2006 | 07:35 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
Many of us have been using the 215's for years now and like them and there is no rubbing running stock.
Old Aug 30, 2006 | 07:53 AM
camminich's Avatar
camminich
I agree, aside from the improvements of ride and such (which is also a benefit from losing the RF), the 215s just look better on the rims.
I went with Pirelli PZero Nero M+S (All season) 215/45/17. Going with the 45 instead of the 40 also makes the Cooper stand just a touch taller. Not good if you like to spend time at the track, but for genral motoring, the increase is great! If you plan on lowering your cooper, or if the offset on the new rims is less than ~35mm consider the 40s. I have heard people say rubbing could be an issue. I have never had any trouble, but I am at stock height with S-lite rims.
Old Aug 30, 2006 | 07:55 AM
Dr Obnxs's Avatar
Dr Obnxs
Watch 40 series tires...
the pressure matters so much more. I've done them, and while you do get better turn in, you whack the crap out of the rims. With the S-Lites, they can take it, but sometimes the tire can't (sidewall gets pinched bad).
For street, stay with the 45s, and as others have posted, they are sweet on the street.
Matt
Old Aug 30, 2006 | 07:59 AM
gstockmini's Avatar
gstockmini
A great site to visit to check exact tire sizes is www.1010tires.com. Go to this site and go to the 'tire size calculator' on the left side of the browser. It will even tell how far off your speedo will be after the tire size change. I used this calculator to determine that a 225/45-16 is a perfect size for a Cooper that came with 195/55-16s stock. They also have a wheel offset calculator to determine what your new backspacing will be after new wheels are installed. Have fun!
Old Aug 30, 2006 | 08:07 AM
camminich's Avatar
camminich
Matt
Yeah baby, 45s rock !
Old Aug 30, 2006 | 08:13 AM
solberg's Avatar
solberg
Thanks for the responses guys. It looks like the offset on the R99's is 48 so I would assume I would be OK re no rubbing with the 215's. I guess I'll go that route based on what I'm hearing.
Old Sep 2, 2006 | 12:47 PM
katmeho's Avatar
katmeho
rock the 215/40
Im running Toyo t1R and they are excellent
Old Sep 7, 2006 | 08:40 AM
MX100's Avatar
MX100
Originally Posted by katmeho
rock the 215/40
Running the same set up and I agree!
vbmike
Oct 15, 2015 04:32 AM
srhodes
Oct 8, 2015 05:17 PM
mbur1024
Tires, Wheels, & Brakes
Nov 3, 2003 12:28 PM
Chief_Charlie
Jul 14, 2003 10:38 AM
Alex@tirerack
Dec 4, 2002 05:03 PM
