Suspension Thump clunk thump?? Help please
Old Aug 15, 2006 | 09:09 PM
Longboard Mini's Avatar
Longboard Mini
I'm going crazy. I have a clunking/thumping sound coming from the rear of the car at slow speeds on bumpy roads. I have been under the car four times and I can't find the problem.
First I thought I had a loose drop link. Not that!
Then I thought the exhaust was loose. No again!
Then I thought it might be my sway bar rubbing. shimmed that but it's still there!
Then I thought it must be a loose hatch. No!
I need help. Has anyone else experienced this sound.
LongBoard
Old Aug 15, 2006 | 09:17 PM
SRTech's Avatar
SRTech
LongBoard
License plate?
Old Aug 15, 2006 | 09:34 PM
vsmini's Avatar
vsmini
try checking the torque settings on your wheels. i had one that wasnt torqued correctly and it moved slightly. made a clunk sound
Old Aug 16, 2006 | 05:04 PM
Longboard Mini
Originally Posted by SRTech
License plate?
Checked that and it's not that but thanks.
I drove around with the rear hatch open and it was still there.
Old Aug 16, 2006 | 08:08 PM
whataricky's Avatar
whataricky
similar issue on my 06 from day one, when pulling into my driveway i get a clunk noise on the right side rear, notice it more and more , when going down a curvy road i get it on both sides in the rear when I "upset" the suspension quick short left and right turns, going in for Driving light install tomorrow and hopefully it will get figured out. I only have 1900 miles so far and have llalready retorqued the wheels. we will see, I'll let you know what they say.
Old Aug 16, 2006 | 08:50 PM
Longboard Mini
It sound the same to me!
Please let me know what you find out.
LongBoard
Old Aug 17, 2006 | 04:45 PM
1FSTMINI's Avatar
1FSTMINI
Same here....I checked the whole rear suspension and found nothing loose.
Old Aug 17, 2006 | 05:39 PM
cabmeister's Avatar
cabmeister
Maybe it could be dry Swaybar bushings.
Old Aug 18, 2006 | 06:48 PM
Longboard Mini
I havn't checked that. Mybe.
LongBoard
Old Aug 18, 2006 | 08:40 PM
cabmeister's Avatar
cabmeister
I had similar noises and found that when I removed both rear wheels also the two rods that are attached to the holes in the bar and moved the bar up and down there was an almighty squeeking . so I then removed the bushing brackets and lubed the rubber bushings all over with brake caliper grease . Not sure if indeed this was the right stuff to use but it worked and has ever since.
I do hope this is your problem ,because its an inexspensive fix .
Old Aug 21, 2006 | 01:12 PM
Wake|MCS's Avatar
Wake|MCS
Any further details? I have some noise coming from the rear of my car as well, on the driver side... Sounds like creaking/squeaking... Any ideas what to look for/check? Thanks...
Old Aug 21, 2006 | 03:54 PM
Kellzir's Avatar
Kellzir
If its squeeking, its probably the sway bar.
Old Aug 21, 2006 | 07:17 PM
whataricky's Avatar
whataricky
Got one answer..... The 2 little ***** that pull the trunk cover up when you open the tailgate will swing far enough over to hit the plastic trim on the inside of the trunk. Basic physics.... still getting my clunk when pulling in the driveway though.
Old Aug 21, 2006 | 07:59 PM
namwob's Avatar
namwob
If its coming from the right rear it could possibly be a loose charcoal filter canister or gas tank leak test pump mounted above/behind the plastic wheel liner
Old Aug 21, 2006 | 08:41 PM
Petrich's Avatar
Petrich
rear tray hitting the rear window wiper motor housing
LongBoard,
This problem has been posted and discussed long, long ago. A common problem. Either the little ***** are bumping something, as has been suggested, or the rear tray is bumping on the rear window wiper motor housing.
An easy fix if that's the case.
Hope this helps,
John Petrich in Seattle
Old Aug 22, 2006 | 05:00 PM
1FSTMINI's Avatar
1FSTMINI
Thats a good one....I had a fault code for the diag leak pump so ima check that out tomorrow at work.
def not the tray since i dont have one in my car.
Old Aug 23, 2006 | 10:00 AM
CSAMF's Avatar
CSAMF
double check the sway bar
I had the same noise. Turned out my swaybar shifted off center. Instead of clearing the strut housing, it was hitting it dead on, preventing the car from lowering on that side. Check the housing for marks underneath the edge.
Old Aug 23, 2006 | 10:02 AM
CSAMF's Avatar
CSAMF
Oh, if your swaybar is centered, it can still hit. The quick fix is to rotate the housing a few degrees so that if it does hit anything, it will hit the rubber bushing up in there.
Old Aug 23, 2006 | 08:37 PM
Longboard Mini
I checked that as well. Pulled the tray out and drove around and it was still thier.
Thank you though.
Longboard
Old Aug 23, 2006 | 08:43 PM
Longboard Mini
Thnak you all for your help.
I will be checking all your suggestions this weekend and will let you all know the results.
Longboard
Old Aug 30, 2006 | 08:37 PM
cabmeister's Avatar
cabmeister
Any Luck with the remedy?
Old Aug 31, 2006 | 01:41 PM
Longboard Mini
Sorry guys,
I am in the middle of a honey do and won't be able to get under the car until next week.
I will report back my findings.
LongBoard
Old Aug 31, 2006 | 04:23 PM
UKSUV's Avatar
UKSUV
I just snapped my ALTA endlink. Heard a clunk only when backing out of my driveway the last couple of days. Will be calling the vendor to get a replacement or an upgrade.
Old Aug 31, 2006 | 04:51 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
i hear a clunk on my 03 MC when i make abrupt left turns
Old Sep 1, 2006 | 12:41 PM
agranger's Avatar
agranger
I had a clunk from the bolts loosening on my swaybar bracket/bushing assembly. When installing the rear sway (again, after getting a new bracket/bushing/bolts), I used a bit of loc-tite.
