Suspension Rear control arm sensor problem
I am installing the rear control arms (Helix) on my MCS . I got the upper and lower arms so I can adjust toe aswell, but the thing is that there is a sensor on upper arm for the stability control.
Does anyone have any idea what to do in regards to angle of installation? Is it the yaw sensor? Is it sensitive to the angle that I will install it in?
Yes, I do have to install it coz the 140km/h+ sweeper are dangerous without it. I don't have any wings for proper download to keep my back end from passing me
Thx
Thx
Thanks latte hiatus,
I had that thread posted through my phone and it didn't turn out that bad.
OMT, What camber setting do you guys run? For track use since I don't use the car alot on the streets.
Appreciate it!
Appreciate it!
Well my current setup...
- Tein SS coilovers (always on the hardest setting)
- H-sport sway bars Fr&Rr (always on the hardest setting)
- Tire pressure 32psi
Why the -2.2.. I can't adjust that since I don't have camber plates... none on the market can be put on my car with out removing the EDFC I have.
Well atleast I believe so, haven't been able to find proof.
OK, since you don't have front camber plates, set the rear camber so it is less the the front camber. You need this so you can get some oversteer. With your coilovers you got some negitive camber up front, but not as much as the rear.
If you really plan the track the car, you should get the front plates. The front tires need about -2 to work properly and not get worn out on the outside edges.
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
