Drivetrain Rear Control arm question..... w/ sensor mount??
Old Jul 11, 2003 | 02:08 PM
Moorlockx's Avatar
Moorlockx
After browsing the forums about control arms I have a question I haven't found an answer to. Have any of the aftermarket companies come out or are planning on coming out with adjustable arms complete with the mount for the DSC/yaw sensor? Could a mount be added to any of the arms presently on the market?
I read about cable tying it on, but would like something a bit more, how do you say, refined. I know these arms were primarily designed for the track guys, but there's a lot of people lowering their cars that never see the track. I've also read that this sensor controls the self leveling headlights too, so even if I wasn't worried about keeping the DSC working properly, I'd sure hate to lose the headlight control.
Any thoughts or unpublished facts out there? Or, do i settle on just replacing the lower arms and living with the toe-in problem?
_________________
03 B/W S model; Madness intake; Cibie 45 lamps; Magnaflow exhaust
Old Jul 12, 2003 | 10:11 PM
Moorlockx's Avatar
Moorlockx
Bump!! Someone out there knows the answer to the questions...I really believe it!
Old Jul 13, 2003 | 04:58 AM
vdubdoug's Avatar
vdubdoug
there are rumors that one will be made for the RDR control arms but it has not been completed yet as far as I know
_________________
Doug
When in doubt, Choose the burrito
Old Feb 21, 2006 | 07:12 AM
Partsman's Avatar
Partsman
Legion_of_Doom
I dug up this thread to see if anyone knows any more about it.
I was just gonna make a custom mount for the yaw sensor, but if there is one out there some where, I would use that one.
Old Feb 21, 2006 | 07:47 AM
Partsman's Avatar
Partsman
Legion_of_Doom
So no one with DSC has replaced their rear arms?
Old Feb 21, 2006 | 08:18 AM
onasled's Avatar
onasled
As far as I know those are for the self leveling headlights and have nothing to do with DSC. That DSC sensor is under the carpet just in front of the hand brake.
If you want to keep these headlight things you can just remove the mount of the stock arm and hose clamp it to the aftermarket arm.
Old Feb 21, 2006 | 08:29 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Thanks Greg.
I knew someone had to know something about this.
Did you get my email?
Old Feb 21, 2006 | 09:14 AM
COR BLMY's Avatar
COR BLMY
I have done it
The "device" is for headlight level not DSC
I have adjustable upper and lower arms.
The problem is that the arm itself spins to do your adjustment, so a bracket will not always be in the same place.
I split a piece of rubber hose and slipped it over the arm.
A hoseclamp holds a "L" bracket (about 1" x 1")
after setting the camber, I actually adjusted the headlights with the bracket by rotating it to move the sensor arm. Once correct tighten the clamp and good to go!
Now as I adjust the camber for track / street I can eyeball the angle needed. I have that down to 1 1/2 turns on the camber adjuster.
Not perhaps the "high tech" answer that you wanted but it does work.
Old Feb 21, 2006 | 09:18 AM
COR BLMY's Avatar
COR BLMY
If you "just clamp the bracket" it will be all twisted and way out of wack to level the headlights.
Old Feb 21, 2006 | 09:26 AM
onasled's Avatar
onasled
You are absolutly right, and your post above is the 'right' way to do what I simply explained. I did it this way at first (your way), but after so many track adjustments I could of cared less just where my headlights were pointing,as long as it was close ...
Old Feb 21, 2006 | 10:00 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Thanks bpago,
I appreciate you chiming in. Homemade is sometimes better than high tech.
Old Feb 21, 2006 | 10:29 AM
BLIZZ's Avatar
BLIZZ
I too made my own bracket as no one had anything available.
But I have toyed with the idea of just removing the sensor.
What happens to the h/lamp adjustment if I do?
I would still do some street driving, but not a lot.
Old Feb 21, 2006 | 10:43 AM
onasled's Avatar
onasled
Sounds like the best thing for you to do is remove the self leveling headlights all together and install lighter basic ones. Can also be a way to pick up some extra cash for some neato track parts ...
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
