Suspension Strut braces
I'd say do a lower frame brace instead.
If you want bling, strut brace. You want improved handling and ride do a lower brace. I really like the OMP. Cheap, simple and works quite well.
Here's a good thread
https://www.northamericanmotoring.co...ad.php?t=45277
Why not do both ? I upgraded part by part, first the frame brace by OMP then the strut brace by JCW. Everytime I noticed a better driving...
OMP makes also a strut brace for cheap money which is not that bad !
Between the 2 I think the OMPO lower brace does more.
Just an opinion....and you know what they're like
I bought an M7 because I believe the plates at the strut towers will help prevent mushrooming of the towers. The jury is still out on if it helps prevent mushrooms. Fingers crossed. It's a pretty nice piece, but I can't tell that it helps with handling. I'm sure it does, because anything that stiffens the car up helps. It's just that the MINI is such a strong car that the benefits seem to be small for the strut bar. That being said I'd still recommend one. I have zero experience with understrut systems.
The M7, JCW, and other braces that lack a method of pre-loading the brace cannot work as well as others that do.
The OMP strut brace, although not particularly pretty, is reasonably-priced, and, with their lower brace, makes a significant improvement in the handling, ride, and feel of the car. Together, they stiffen the whole front of the car substantially.
My conclusion is that their lower brace does make a significant low-cost upgrade by itself, and that the OMP braces are a bargain compared with some of the bling-oriented competition that doesn't work as well.
Save your money. They (uppper and lower strut braces) don't do much but lighten your wallet. And a lighter wallet improves handling as well (especially if you cary allot of change)!!!
A drivers course, Better tires and lighter wheels and are far better mods.
I bought an M7 brace to help keep the strut tower mushrooms at bay. I guess it's done that & it looks nice. As far as improving the handling, for me it's done nothing. I feel no difference at all. The MINI is a pretty stiff car already.
I put a tower brace on my Miata & it did make a noticeable difference. Compared to the solid structure of a MINI the Miata is a real flexible flyer.
