R52 Does anyone elses top rattle?
Old Aug 1, 2006 | 05:24 PM
idoc's Avatar
idoc
I have already had to have to plastic center bar replaced because of rattling and it still seems that when I go over a bumpy patch that center piece rattles and also somewhere in the rear of the car. With the top down there is no problem. Does anyone else experience this? I don't know if its the car or my car!
Old Aug 1, 2006 | 09:43 PM
litabelle's Avatar
litabelle
Neither my husband's or my convertible have this sound. Hope you can get it fixed!
Old Aug 1, 2006 | 09:48 PM
mistro's Avatar
mistro
Mine is rattling too, both the center top passenger side center bar and maybe the rear glass (I know I can't see what rattles in there) but if you tap on my rear glass there is a tinkling sound. Just apparant now that the top is up so much because of the heat
Old Aug 2, 2006 | 08:21 AM
chuckyTLC's Avatar
chuckyTLC
I get the rattle, but only when the sunroof is open. On the driver's side.
Old Aug 2, 2006 | 08:23 AM
goaljnky's Avatar
goaljnky
My squeeks like there is no tomorrow. I really should have the dealer look at it.
Old Oct 14, 2006 | 04:05 PM
MY4thMINI's Avatar
MY4thMINI
me to
i get that same sqeak/rattle on the drivers side when the sunroof is open
very anoying ..hope it can be corrected
i am waiting for my 10 k in service
would love to hear if others had it ...and if it was corrected ...
Old Oct 15, 2006 | 09:10 AM
horn's Avatar
horn
let them check the isolation around the cables that run through this plastic center bar (they did with me, renewed the isolation and the problem was gone)
Old Oct 16, 2006 | 02:27 PM
idoc's Avatar
idoc
Since my first post I have had the car to the dealer no less than 3 times for all the rattling. They have fixed the noises coming from the center bar, but now I have it coming from the side of the passenger seat and from the back somewhere. I have finally figured out why they want you to keep the top down 90% of the time! This is extremely frustating as the car does not make a sound when the top is down.
Old Oct 16, 2006 | 08:56 PM
DSA's Avatar
DSA
Mine is in the top rear passenger area only in hot weather with the windows up.I have tried silicone no luck if I lower the rea window slightly it stops very annoying since my hard top mini never rattled.
Old Oct 17, 2006 | 03:53 AM
idoc's Avatar
idoc
DSA,
I have the same rattle as well and the dealer said that there is a service bulliten out on this for a part replacement, althought the parts are on backorder (for a change) so you should see the dealer about this.
Old Oct 17, 2006 | 07:26 AM
ericscottf's Avatar
ericscottf
Regarding tapping on the back windshield - i had this problem, and realised the trim was coming off of the window on the inside. told the dealer, they took care of it (i think they superglued it).
Old Oct 17, 2006 | 07:52 AM
am0eba's Avatar
am0eba
I have the rattle - passenger-side only, and only when in sunroof mode... I rarely use this mode, but the noise is annoying.
I've also just started to notice the crescent-shaped scratches on the passenger-side rear quarter window...
_Dave_
Old Oct 17, 2006 | 07:56 AM
bamatt's Avatar
bamatt
No rattles here. Riders usually comment on how quiet my Mini is for a convertable.
Old Oct 17, 2006 | 05:24 PM
MY4thMINI's Avatar
MY4thMINI
sure
sure... rub it in, you and your purfect quiet roof
Old Oct 18, 2006 | 05:52 AM
mhend's Avatar
mhend
I'm getting a rattle, now that the weather has gotten cooler. I'm thinking that the metals and pastics are shrinking ude to the drop in temperature. It is very anoying until I turn the radio/CD on. There was mention of a sevice bulletin. Did they say what the cause was from?
Old Oct 18, 2006 | 07:28 AM
chuckyTLC's Avatar
chuckyTLC
I get the same as mhend as well - when it gets cold, the whole top rattles. Think this is "normal" (but very annoying!)
Old Oct 18, 2006 | 04:59 PM
idoc's Avatar
idoc
How can a top that rattles so that its constantly "annoying" be normal? It almost takes the fun out of the car when the top is up.
Old Oct 18, 2006 | 07:03 PM
Capt_bj's Avatar
Capt_bj
First rag top?
First time rag top owner?
I don't have a Cooper 'vert. But there is a rag top sports car in my driveway now, and over the years I've owned a Mustang and a VW rag top in addition to the one I've had for 11 years.
Convertibles squeak and rattle ... it is one of the joys of topless driving. To expect them to be as quiet as a hardtop is like expecting a Mini or MG not to leak oil. 1 in 10,000 maybe, but not the norm
Old Oct 19, 2006 | 03:52 AM
idoc's Avatar
idoc
So I guess you have never had a porsche, jaguar, or BMW convertible, as I have owned all three and I have not experienced the problems that I have with the mini. It was not my expectations to compare it with a MG. I also expected just a little better quality out of a BMW product.
Old Oct 19, 2006 | 06:33 PM
Capt_bj's Avatar
Capt_bj
You get what you pay for
It ain't a BMW ... it is a $20k MINI, get over it. Today an MG would cost more. Pors' Jag' BMW' .. how many cost as little as ur lil MINI? Not that I believe they had no noises
In the 90's the VW 'vert was readily acknowledged as having a better constucted soft top than a Mercedes. The removal of the hard top introduces body flex primarily due to the fact that the car was not designed as a 'vert but a hard top that they sub' cut the top off. Couple that with all the rubber in the seals and you have squeeks. You have 20 years experience with rag tops and no squeeks? You must walk on water too. Even a ground up vert like the MX-5 has body flex...there just ain't enuf steel to prevent it.
Want quiet - don't buy a rag top. My suggestion - sell your MINI and buy a Bentley.
or
Try a little KY on the rubber parts and see how many noises go away.
Old Oct 26, 2006 | 01:53 PM
bamatt's Avatar
bamatt
Sometimes you have to read through some doosie posts to get any help around here . I really hope they can adjust your top for you idoc. Go to the dealer & have them work on it & if they try to tell you it is normal cry BS because mine is really amazingly quiet so I know it is possible.
(sorry didn't mean to rub it in again MY2ndMINI )
Old Oct 26, 2006 | 02:38 PM
idoc's Avatar
idoc
Thanks bamatt, and I hear ya. My car is going in on Tues for the 4th time. This time to replace pieces on the top of the rear window. It still rattles in the back and on the side, almost like the nuts were not tightened all the way. I know this is not normal because my friend has the same car and his top is as quiet as yours. I just don't know how many times I should let them try and fix it before I have to claim that its a lemon, or insist that they give me a new top. I know it has to be the top because with the top down it is perfectly quiet.
Thanks again
Steve
Old Oct 31, 2006 | 11:32 AM
AggieMini
Scarlett made a scary noise when I put her top down today... then I laughed because she's probably just trying to be scary and haunted...it is Halloween today.
That crazy girl!!
Old Nov 1, 2006 | 09:29 AM
Wesmonster's Avatar
Wesmonster
scary noise
was your scary noise a loud pop, mine did a few months ago and afterwards I had a piece of plastic cover trim on the passenger side always poping off. I glued it back in place but when I did I noticed that the fabric on the inside of the C pillar passenger side was not taught like the other side. When I took it to the dealer they found an elastic cord or strap on the inside C pillar had broken and the fabric was knocking off the trim piece. The fix was simple, but ever since this repair I've noticed that my top now has several rattles it didn't have before and the top doesn't close as smoothly as before.
Old Nov 1, 2006 | 11:33 AM
SilverHawk's Avatar
SilverHawk
Quiet Rag Top
I've owned a number of convertibles. So far my MINI is quieter than any other convert that I have owned. Mine is only two months old so perhaps things are still tight. A simple solution - Put the top down!
