R50/53 I hate the power windows on my MINI!
Old Jul 30, 2006 | 12:53 PM
SSMini's Avatar
SSMini
Anybody else have this problem..... Today I get in the car and hit the power window switch and nothing. Drivers or passenger window does not work. I move the switch on the pass. side oh about 20 times and it works finally. I move the drives side about 50 times and nothing. I hear the relays and all working but the window does not work.(By this time Im ready to rip the switch out.) I drove about 20 miles moving the switch and nothing.(Went to the parents house for luch.) I get 100 yards from my house and it works. What gives. Its done this in the past, but I would only have to toggle the switch a few times and it would work. It was very odd that BOTH windows went out this time.
Old Jul 30, 2006 | 12:57 PM
QWKSLVR's Avatar
QWKSLVR
COULD IT BE THE FUSE..??
Old Jul 30, 2006 | 12:59 PM
thefuturequeenofnebraska's Avatar
Window motors?
Old Jul 30, 2006 | 01:01 PM
Gromit801's Avatar
Gromit801
Sounds like a bad ground or loose connection somewhere. Might be bad switches.
Old Jul 30, 2006 | 01:02 PM
SSMini's Avatar
SSMini
The fuses check out fine, but to have both go out at the same time? I think it may be a bad connection somewhere.
Old Jul 30, 2006 | 01:03 PM
SSMini's Avatar
SSMini
I thought about taking it to the dealer, but Im sure they will say that the aftermarket radio caused it....
Old Jul 30, 2006 | 01:07 PM
ToBFree's Avatar
ToBFree
Try the dealer first. Classic in Mentor replaced my driver's side motor under warranty with no discussion. And I'm the second owner. I did notice the window failed to work on hot days. There's a thread on here somewhere about the window motors.
Old Jul 30, 2006 | 01:09 PM
Deli's Avatar
Deli
Last night I came out of the movie theater (Woody Allen's Scoop--a must see!) and the passenger window would not go down. Playing with the toggle switch doesn't help. I checked both of the window fuses (just in case I was looking at the wrong one) and they are fine. I've got an 03 MCS with 56K miles...first window problem with it.
Old Jul 30, 2006 | 01:11 PM
SSMini's Avatar
SSMini
Mine is a 03 with 24000 miles on the clock....
Old Jul 30, 2006 | 01:16 PM
ToBFree's Avatar
ToBFree
Mine's a 2002. The window motor was replaced at the 25,000 mile service inspection last winter. Now I'm up to 34,500 miles and everything is still working.
I believe the window motor problem is rooted in the way the windows drop and rise when the door is opened. A nice feature to seal the windows, but everytime you open a door that motor does a little 1/4" move. You'd think after a period of time it would wear out in that start spot. Just a thought.
Old Jul 30, 2006 | 01:20 PM
Deli's Avatar
Deli
OK, so I'm out of warranty. If I replace a window motor at a MINI dealer, how much should I expect it to cost me?
Old Jul 30, 2006 | 02:22 PM
ToBFree's Avatar
ToBFree
Sorry, they never told me that. In that situation I'd order one from the dealer, pick it up, and learn how to open up a door and install it. I did a short search for a window motor with no luck. So, I can't help with price or seller. Hmmm. What good am I?
Old Jul 30, 2006 | 02:35 PM
strz0001's Avatar
strz0001
Window motor part numbers.. (for my 2002 MC)
ClassicMini should give you this for 20% off.
67626955876 for 82.75
other side is 67626955875
Old Jul 30, 2006 | 04:21 PM
GBMINI's Avatar
GBMINI
Just try the old proven method:
Click the switch to make the window move while at the same time giving a good thump to the door panel, right below the handle you use to open it.
This'll jog the motor free and it'll work - for a while. Days? Weeks? A while, at least.
Old Jul 30, 2006 | 04:39 PM
katesmini's Avatar
katesmini
Similar to what GBMINI said, this thread may help...
https://www.northamericanmotoring.co...ghlight=window
Old Jul 30, 2006 | 07:29 PM
illegalprelude's Avatar
illegalprelude
wow, simple idea, dealer.
Old Jul 30, 2006 | 08:18 PM
polizei's Avatar
polizei
Yea, you DO have the factory warrenty that comes with the car no matter what, correct? If you don't, something is very wrong...
-Cody
Old Jul 31, 2006 | 03:34 AM
Deli's Avatar
Deli
They have the factory warranty. I did, but I'm up to 56,000 miles so mine is expired.
Old Jul 31, 2006 | 08:29 AM
joedude99's Avatar
joedude99
Windows
My windows failed at 25K also. It's a frequent warranty item. Good luck!
Old Aug 8, 2006 | 12:19 PM
movieman's Avatar
movieman
So, does anyone have a "how to" on replacing this motor? I took off the panel, and 3 screws hold the motor to the door frame, but I can't figure out what else needs to be done. It still won't come loose. :(
Dec 23, 2015 10:36 AM
wkp1219
Nov 13, 2015 07:52 AM
Dashdog
Aug 10, 2015 06:17 AM
USA-RET
Aug 6, 2015 09:22 PM
