Interior/Exterior How long to wait before installing badge over boot stripes?
Old Jul 18, 2006 | 11:04 AM
schreyerplace's Avatar
schreyerplace
I'm ready to install my DIY boot stripes from Aesthetic Creations and I was wondering how long I should wait after the install before reinstalling the Cooper S badge.
And a follow up question of how long before the vinyl can withstand a Z7/Z5/Z6/Z2/Z6... treatment.
Thanks.
Old Jul 18, 2006 | 02:25 PM
kenchan's Avatar
kenchan
if you're not using soap solution, i think you can mount the emblem right
after installing the stripes.
if you do use soap solution, i would give it at least 24hours in the dry or
toast it with a heat lamp for a couple of hours (or just leave it out in the
sun).
Old Jul 18, 2006 | 03:23 PM
dragonflyer's Avatar
dragonflyer
Thanks.
Since the install will be a dry install you can put the badge on right after. Just follow the instructions for the install and it will be no sweat. Added hint from the DIY install thread will help too.
Old Jul 18, 2006 | 03:51 PM
schreyerplace
Excellent...wish me luck!
Old Jul 18, 2006 | 04:06 PM
schulzmc's Avatar
schulzmc
Post your results! I'm waiting for mine to come (just ordered yesterday) and am trying to learn all I can before I do my install.
Old Jul 18, 2006 | 06:07 PM
schreyerplace
It took me about an hour. I was extremely nervous that I'd mess it up but it proved to be pretty simple. It started getting dark so I didn't feel comfortable putting the replacement CooperS badge back on so I'll do that tomorrow.
The Aesthetic Creations instructions were very helpful and the DYI stripes thread also cleared up some questions I had: https://www.northamericanmotoring.co...ad.php?t=73509
I used the 'dry' technique outlined in the AC directions although others have mentioned using a slightly soapy solution that is supposed to reduce air bubbles and allow for some slight movement if you get a crease or fold. The dry technique worked fine for me.
After viewing some images on NAM I decided where I wanted the stripes (left to right) so that the badge would land with the C fully in the black rather than partially in the white. Then I removed the badge with dental floss and cleaned up the adhesive with alcohol. I then washed and dried the boot where the stripes would be placed to remove all Zaino and to provide a good base for the vinyl. I taped the stripe in place and double checked my measurements.
I then peeled back the stripe from the top and removed the top half of the backing and started working very slowly up the vinyl keeping it with a soft curve up and away from the boot. I found that if you pulled very tightly on the vinyl it tended to crease severely around the rubber squeegee making it susceptible to wrinkling. For me, a soft curve to the vinyl while working slowly seemed to work best.
Then I peeled the backing off the bottom half and repeated the slow march to the bottom edge of the boot.
Rinse, lather, and repeat on the other side and I'm done (minus the badge replacement which I'll do tomorrow).
Old Jul 18, 2006 | 07:52 PM
acitydweller's Avatar
acitydweller
the stripes look fantastic
Old Jul 18, 2006 | 09:40 PM
Kimini03's Avatar
Kimini03
Looks like you did a great job!! The stripes look sharp!!
Old Jul 19, 2006 | 08:44 AM
ImagoX's Avatar
ImagoX
Great work and glad my thread helped!
Old Jul 19, 2006 | 09:18 AM
Crashton's Avatar
Crashton
Very nice job! That completes the striped look.
Old Jul 21, 2006 | 06:31 PM
schreyerplace
This thread has gone a little stale but I thought I'd finish what I'd started and show how the badge turned out after I finally got it installed the following day.
Old Jul 21, 2006 | 06:36 PM
dragonflyer
That's a nice lookin badge you got there Mate
Old Jul 22, 2006 | 08:36 AM
Crashton's Avatar
Crashton
Could you tell us where you found that flags badge? Very nice.
Old Jul 22, 2006 | 10:26 AM
schreyerplace
http://www.americanminimates.com/bling.html at the bottom. They're one of NAM's vendors from the front page.
Old Jul 22, 2006 | 11:11 AM
Crashton's Avatar
Crashton
Thank you!
squawSkiBum
Oct 2, 2015 09:21 AM
speedbird_1
Aug 15, 2015 04:44 PM
