Suspension Best Rear Sway
Best Rear Sway
Ok,
I'm sure this is already on here but I can't find it...searching for rear sway bar bring up a ton of posts.
so..what are the thoughts on the best rear sway bar for the $$?
thanks
~R
thanks
~R
This is kinda like asking what the best color is... (Pepper white, of course!
I like the H-Sport Comp bar that I put on Jango... big bar, stiffest of the bunch (without going to a full racing bar like the Webb Motorsport full adjustable), 3-point adjustable, Zerk fittings for easy lubrication of the bushings, heavy-duty bushings and hardware, hollow for light weight.
I've heard many people (that I respect) say that this is too much bar for daily driving (and they are probably correct). They generally recommend the larger Alta bar that costs about $40-60 less. I got a great deal on the H-sport at the Dragon, so I couldn't pass it up... I figured that I could just leave it on the softer setting.
)I like the H-Sport Comp bar that I put on Jango... big bar, stiffest of the bunch (without going to a full racing bar like the Webb Motorsport full adjustable), 3-point adjustable, Zerk fittings for easy lubrication of the bushings, heavy-duty bushings and hardware, hollow for light weight.
Originally Posted by bruce_wayne
Ok,
They all basically do the same thing and unless you going racing for real, I doubt it really matters. If anyone can find ANY aftermarket sway bar (not the end links) that have actually broke, please post. Bottom line ... IMHO read what each vendor has to say and form your own opinion ... thats what I did.
Here's a general discussion from last year
https://www.northamericanmotoring.co...light=sway+bar
And a link to Randy Webb's thoughts on them here (scroll to bottom)
For the $, I'd say Rspeed off of ebay is a brilliant decision. Hey
, that's what I did!
If you are in a Cooper, it's a nice modification to find someone with an MCS who has upgraded and replace your stock bar with their spare MCS bar.
If you optioned the Sports Suspension Plus on your Cooper, you already have the swaybars that come on an MCS.
Even if you didn't, I'd say that if an MCS owner wants to give you their take-off for free, sure, go for it. But I wouldn't pay much for one. If you're going to go through the labor of changing your rear swaybar (admittedly not much, but still) you might as well spend a few dollars more and get an adjustable one instead of someone's MCS leftovers.
IMHO.
Forgive me for confusing the issue
. One of the things I don’t like about stiff anti-sway bars is the reduction of independent suspension travel. In certain stock racing categories modifications to the rear suspension are not allowed so to counter wheel lift out of tight turns the front sway bar is swapped for a smaller diameter one. For an MCS that would mean trading for a standard cooper bar
. Just think you get to keep stock independent suspension action, reduce understeer (for the most part a function of the relationship between front and rear stiffness), and wheel lift, all at the same time, by going smaller up front instead of larger out back
. I took a ride in an MCS set up like this on an autocross course and the car was not sloppy
Now for the original question; the best sway bar for the $$ (or less), stay stock
. I took a ride in an MCS set up like this on an autocross course and the car was not sloppyNow for the original question; the best sway bar for the $$ (or less), stay stock
On one of the threads, someone posted pics on his install of an RSpeed swaybar. The description of the install included grinding of the area of the body that contacted the bushing and covering the grind with silicone...did anyone else have to grind at the body? Are there rubbing issues with any of the major choices (Rspeed, ALTA, H Sport)?
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
The grinding may be dependent upon the build date of the car. There were some changes made in the rear of the car in the suspension area, remember. For instance, for a long time the JCW suspension was not allowed on early cars because there wasn't clearance for something back there without grinding something away.
I had the first and second H-Sport Comp production runs. Both had contact issues of some kind (not confined to the bushing bracket); very little could be done about the first version, for both early versions some relief could be had by slotting the bushing bracket holes. My build has a disparity between the mounting holes from one side to the other so that was partially to blame, but I have seen minor body contact at the bracket in another early build install.
I have the H-Sport Comp bar and haven't had any problems with it. It works great with the JCW suspension. I've used the softest and middle settings and both were fine for daily driving. The middle setting does lose a lot of rear wheel independence and also can have liftoff/braking oversteer when pushed hard. I've settled on keeping it at the softest setting for now.
If I were to do it all over again I would probably go with the H&R rear sway bar. They offer both 18mm and 19mm sizes with bushings that don't need to be lubed. They aren't hollow and as stiff as the H-Sport, but they would give more independent wheel travel and would be plenty for street purposes.
I think the reason most change the rear bar is because it is easier to change than the front.
I seem to remember a yellow and white striped box. Everyone just brought their bars over to the house and we did a 6 car install day.
If you want an infinitely adjustable swaybar, but dont want to spend big loads of cash, you should check out the Ireland engineering bar. It comes with the end links and is infinitely adjustable...all for a low price
(and it isn't even the one i have...i have the h-sport and like it, but i think the infinite adjustability would be awesome)
Originally Posted by snid
I'm not a big fan of this advice...
IMHO.
IMHO.
It includes 19mm swaybar and adjustable droplinks.
It's a great swaybar and makes the car handle a lot better!!
