R50/53 Dents/dings in the Supercharger radiator fins
I am noticing some dents in the supercharger radiator. Am considering installing a mesh or screen to prevent rocks and debris from hitting the fins of the radiator up top. any suggestions?
you mean something like this?
it's easy to do yourself too... just go to HD and get some rain gutter guard, a pair of tin snips (if you don't have them already) and go home and start working. the plastic piece that goes under the hood by the scoop comes off real easy with 2 screws and 2 8mm bolts. then make the gutter guard fit in the opening and you're set.
A simple scoop grill will help. I do like the ones from Grill Guy as he does the hard part for you.
I'm not sure how you would attach it on the lower side. For the SC intake I just sandwiched it in.
Thanks, I was looking for where to pick one of these up. Not bad at $15 too
http://www.marketworks.com/StoreFron...64&i=144049546
wad that mesh into a ball & stick it back in the scoop as a lame demonstration of how you will be restricting airflow. The fins are easily straightened with a knife blade. Don't look at the radiator fins. Its needed for cooling also.
Originally Posted by bpago
I have found a "Pick comb" at the local drug store.
It is plastic and the perfect size to straighten 6 rows at once.
Originally Posted by claancy
Harbor Freight sells a Radiator Fin Straightener, with six different sizes of "combs" and it's only $2.49.
Originally Posted by ScottinBend
........or a bird nicely roasted. That is why I have a grill.
I've catch one with my Subaru Impreza's hood scoop...
It was gross.
My Scooby's hood scoop was larger than the MCS's one too.
Btw, to stick back to the main topic, my intercooler has 2-3 dents on it, but nothing major yet.
fkrowland
Sep 30, 2015 10:30 AM
