Suspension Squeeeeeeeky spring
Old Jun 23, 2006 | 06:30 PM
DaveMini's Avatar
DaveMini
Squeeeeeeeky spring
Installed double adjustable Konis on my MCS, and now the drivers side rear spring squeaks like a mouse being sodomized. If you wack the spring with a mallet to move it a bit on the perch, the sound goes away for a while. Nothing wrong with the spring, checked all the bolts, and if I have a helper gently bounce the car to make the squeak, I can grab the coil to silence it. Any suggestions other than turning up the stereo?
Old Jun 23, 2006 | 07:49 PM
kenchan's Avatar
kenchan
the source of the squeak is between the spring and top mount bushing?
did you try a little lube between there? might want to even wrap the
spring with teflon tape where it meets the mount..might help.
Old Jun 23, 2006 | 08:17 PM
lhoboy's Avatar
lhoboy
Yep, you should always use a light coat of lithium (white grease) when installing springs. Will last forever, even in rainy climates.
Old Jun 23, 2006 | 08:23 PM
kenchan's Avatar
kenchan
dang it, the one time i dont recommend white lithium, someone recommends
it.
Old Jun 24, 2006 | 07:14 PM
lhoboy's Avatar
lhoboy
it.
In a pinch, it works great as sunblock too!!
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
CooperSharp
Oct 12, 2015 09:21 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
nshannon29
Sep 30, 2015 05:21 PM
