Suspension Shock Install Problem
Old Jun 18, 2006 | 08:04 AM
headhog1's Avatar
headhog1
I ran into a problem while installing Koni FSD shocks on the front of my 06 MCS. The rear installation is no problem.
Many people have installed Konis and suggested the following method:
1. Remove the swaybar droplink from the strut using a 16mm wrench and 5mm allen key to hold the bolt stationary. You will probably need to keep some compression on the suspension to get the bolt out. 2. Take the brake and sensor lines off the strut. 3. Remove the lower pinch-bolt that attaches the strut to the hub carrier. 4. The hub carrier is now free to move down away from the shock housing. 5. Remove the top three mounting nuts in the engine compartment. 6. Catch the strut assembly as it falls out.
I am happy for those lucky ones that are able to use this technique. But I get stuck at step 4. The hub carrier will not move down far enough to get the shock housing out. I guess for some Minis this technique works, and others it does not. The official BMW/MINI instructions are to undo the balljoint from the base of the hub carrier to allow for the needed travel
Another technique is to compress the shock while it is still on the car using a floor jack and then strap the springs in their compressed state. This should allow you to remove the strut. I am going to try this next since I don’t have a balljoint tool.
I just wanted to post my experience so others will be better prepared if they plan on installing new shocks.
Old Jun 18, 2006 | 08:12 AM
Dr Obnxs's Avatar
Dr Obnxs
I have an 02...
and I used the canvass strap method, and a little coersion.... It will come, but the driver front corner is the only tough one.
Also, some tugging may give you a little more room...
It's only a bit*h the first time....
Matt
Old Jun 18, 2006 | 08:19 AM
onasled's Avatar
onasled
Just give that hub a good hard downward kick with the bottom of your foot. It always works for me.
Old Jun 18, 2006 | 08:30 AM
kenchan's Avatar
kenchan
i used a small piece of wood and a mallet and tapped it down.
then grabbed the rotor, turned it cw/ccw a little and the struct
collapsed off the car. not sure about those new dampers, but
the stockers were not hard to remove/install.
Old Jun 18, 2006 | 08:43 AM
JCampos's Avatar
JCampos
If you can, popping the two joints on the bottom will definitely get it out. This requires certain tools but it definitely saves time and energy from kicking, cursing, yanking, spitting, and more cursing to get that damn thing out.
Old Jun 18, 2006 | 08:46 AM
Dr Obnxs's Avatar
Dr Obnxs
I love all the
delicate techniques and procedures used on our fine precision autos!
Matt
Old Jun 18, 2006 | 09:03 AM
qwertmonkey's Avatar
qwertmonkey
I used a jack to hold it in place, then let the strut fall out. Same with the re-installation
Old Jun 18, 2006 | 09:08 AM
weezer2282's Avatar
weezer2282
I did mine a few weekends ago. The driver side I got out by compressing the spring, but I tried the same with the passenger side and it wouldn't work. The passenger side I had to break the joints loose to free the hub and then it was no problem. Mine is an '05 auto so I don't know if that makes a difference or not. The new struts and springs were easier to put in.
Old Jun 18, 2006 | 09:25 AM
JCampos's Avatar
JCampos
I got driver side out without even compressing the spring..... I have no idea why this side likes to come out so much easier thant he passenger side. I did this exact same thing last week and it was a cinch.
Old Jun 18, 2006 | 11:30 AM
AZMCS's Avatar
AZMCS
Just drop the ball joint. All you need is the 15mm wrench and a jack to support the knuckle once it comes off.
Old Jun 18, 2006 | 12:04 PM
002's Avatar
002
No need to pop any joints. Just disconnect the arm from the hub by removingt the two 13mm bolts underneath the joint. Use a pry bar to seperate the hub from the arm. A sharp blow with a mallet will do it also. Now you will have plenty of room.
Old Jun 18, 2006 | 12:58 PM
Wesport's Avatar
Wesport
I had the same issue - I am doing my FSDs right now. I lowered the subframe about 1" and got it out. I needed to lower the subframe anyway as I am also doing powerfelx control arm bushings. I am snapping some pictures. Doing the bushings is not for the faint of heart.
Wes
Old Jun 18, 2006 | 12:59 PM
JCampos's Avatar
JCampos
Wes
Bushings SUCK!
Old Jun 18, 2006 | 04:13 PM
002's Avatar
002
Originally Posted by JCampos
Bushings SUCK!
They aren't too bad with the right tools.
Old Jun 18, 2006 | 04:15 PM
JCampos's Avatar
JCampos
Never done MINI bushings but I hated doing them on E36 M3s.... They arent necessarily hard to do, just a pain in the ****! I definitely had all the right tools... including a shop and a lift
Old Jun 18, 2006 | 04:22 PM
002's Avatar
002
I've done a couple sets on mini's. There are some things to look out for if you leave the subframe in, but it can be done. I haven't decided if which is quicker, subframe in or out.
I have a set of powerflex cheap if you want them.
Old Jun 18, 2006 | 04:24 PM
JCampos's Avatar
JCampos
I should be ok for now but Ill let you know if I change my mind. Ill be under the car on Tuesday or Wednesday and ill take a look at them all while im under there.
squawSkiBum
Oct 2, 2015 09:21 AM
Emnotek
Aug 13, 2015 05:47 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
