R50/53 steering wheel vibration
Old Jun 15, 2006 | 06:57 PM
takingcurves's Avatar
takingcurves
when i drive my wheel pivots left and right ...just had a wheel alignment and balance...any other ideas or people w/ similair problems
Old Jun 15, 2006 | 06:59 PM
Motor On's Avatar
Motor On
Trammling, maybe; do a search for more info I suck at explaining this phenomena, but I feel it everyday witht he poor quailty of chicago roads.
Old Jun 15, 2006 | 07:02 PM
C4's Avatar
C4
Bent rim, or out of round tire. You could also have suspension damage of some sort.
You have stock tires/rims or aftermarket?
Old Jun 15, 2006 | 07:03 PM
jonnieoh's Avatar
jonnieoh
Maybe you have a warped brake rotor, or two!
Old Jun 15, 2006 | 07:08 PM
mitchman's Avatar
mitchman
Sounds like you have a wheel! (I hope I'm wrong)
You should find a tire place that has a "road force balancer". It will tell you if you have a bad tire.
Otherwise I'd check for worn tie-rods. How many miles does the car have on it?
Old Jun 15, 2006 | 07:10 PM
C4's Avatar
C4
Yeah balance those tires/rims. This is often an area where vibration takes place.
Old Jun 15, 2006 | 07:52 PM
takingcurves
24,000 miles on her .....i just had the dealership balance rotate and align ... maybe they missed this ...also the brakes were just done .and i think they would have seen suspension damage while doing the breaks...thanks for all the info everyone
Old Jun 15, 2006 | 08:56 PM
MiniBetterThanBeer's Avatar
MiniBetterThanBeer
If you mean that sometimes the steering wheel seems to pull itself to either side, it may be the runflat tires. I believe it's called tramlining, as someone already posted above. I used to think there was a problem with the power steering motor since it often happened while going over uneven surfaces like heat-ruts on highways. Then I switched to non-runflats and the problem disappeared entirely.
Old Jun 16, 2006 | 06:04 AM
takingcurves
no i can drive straight but if i let the wheel go the car stays straight but the wheel gos crazy left to right and back and forth
Old Jun 17, 2006 | 06:20 PM
MiniBetterThanBeer
Wow, that is nuts! When you turn the steering wheel, do the wheels turn as much as they should? And when the steering wheel moves by itself, how much play are you talking about? Is it just a few degrees or is it from, say, 12 o'clock to 11 and 1?
Old Jun 18, 2006 | 06:40 PM
takingcurves
i would say it goes from like 12 to 1155 to 105
Manny_cooper
Sep 10, 2015 11:09 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
trw92a
Aug 26, 2015 01:47 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
