Uh-Oh.... What could I have done?
Old Jun 8, 2006 | 09:10 PM
JCampos's Avatar
JCampos
Today I FINALLY got my MINI running again... however, the ECU was just out loose and the bumper wasnt even on. So.... we unplugged the ECU, put the bumper back on... I plugged in my unichip... and I tried to start again.
tick...tick...tick....
I go check out everything in the engine and realize that I pulled a stupid and left one arm of the unichip plugged into itself, one arm of the ecu plugged in to the stock part, and one arm of the ecu plugged into the unichip.
I unplug the unichip and try to start again.....
Now I have noticed that when I try to turn the ignition the headlights flicker with the ticks and the windows roll down a notch at a time with the ticks.
Now I am stumped. I checked all of the fuses that are in the engine bay and they look fine. I can check the ones in the foot well tomorrow when there is more light. What the hell could I have done? I really hope I dont have to shell out the cash for a new ECU
Old Jun 8, 2006 | 09:15 PM
Yucca Patrol's Avatar
Yucca Patrol
You are supposed to disconnect the battery before disconnecting the ECU. Hopefully you didn't fry it. Try disconnecting the battery and re-installing the ECU and unichip. Say a little prayer to the MINI gods and you might be fine. . .
Old Jun 8, 2006 | 09:20 PM
MSFIT's Avatar
MSFIT
Old Jun 8, 2006 | 09:22 PM
MSFIT's Avatar
MSFIT
even though it was plugged in funky it did try to start at first...then it started just clicking after that...
JCampos's Avatar
JCampos
Been there, done that.
Old Jun 8, 2006 | 09:23 PM
JCampos's Avatar
JCampos
Yea... this is the only reason I don't think that unplugging it before disconnecting the battery did anything. It did the same thing before and after I fixed it.
Old Jun 8, 2006 | 09:26 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Make sure the battery is not low on charge.
Old Jun 8, 2006 | 09:27 PM
MSFIT's Avatar
MSFIT
ya...so =/
it sounds like the start solenoid is popping but the starter is not spinning...
MSFIT's Avatar
MSFIT
omg I bet that is so it!!!!
we left the radio on derrrrr
Old Jun 8, 2006 | 09:29 PM
JCampos's Avatar
JCampos
I doubt it... a low battery wouldnt make the lights flicker and the windows roll down
Old Jun 8, 2006 | 09:31 PM
MSFIT's Avatar
MSFIT
its worth a try..
my car kinda did that after they left the key in position 2 when towing it to edge onetime...got to edge and it just clicked and flashed
Old Jun 8, 2006 | 09:37 PM
JCampos's Avatar
JCampos
its worth a try..
Yea I guess its worth a shot.... but Im not talking about the lights inside the car.... Im talking about the headlights.... the headlights are turning themselves on with each click.
Rossii's Avatar
Rossii
Thats what happens in the BMW's. Low battery makes all the lights flicker. Never seen the windows roll down but seen other strange things. In the 7's the headrests would go up and down by themselves. Try charging the battery and see what happens.
Old Jun 8, 2006 | 09:40 PM
not-so-rednwhitecooper
Yep, sounds like a typical low voltage condition....
any time my voltmeter reads less than 11 volts, thats exactly what happens.
Old Jun 8, 2006 | 10:20 PM
JCampos's Avatar
JCampos
ITS ALLIIIIIIIIIIIIIIIIIIIIIIIIVE!!!! Just the damn battery No more listening to Giants games while the car is off
Old Jun 8, 2006 | 10:24 PM
002's Avatar
002
congratulations! You must feel great now that the pressure is off. Now we need a run as a welcome back.
Old Jun 8, 2006 | 10:28 PM
JCampos's Avatar
JCampos
Hell yea... just some odds and ends to tie up... change rear brake rotors, flush the fluids, put air in the tires.... thats about it Got some new plugs and a webb intake on the way also
