Interior/Exterior How do you remove a sunroof graphic?
Old May 7, 2006 | 05:27 PM
Krut's Avatar
Krut
My two month old solid white factory sunroof wrap decided to start come off on my way home from MOTD (it actually made a tearing sound while I was driving in the rain).
So I'm going to take it off because it looks like this...
So let the photoshopping begin to make something truly unique!
Old May 7, 2006 | 07:15 PM
kenchan's Avatar
kenchan
i would pull gently and apply some ammoniaD windex and window scraper
(razor blade) if needed.
Old May 7, 2006 | 07:52 PM
Smokey's Avatar
Smokey
And if needed apply a little heat from a blow dryer. Also, try and keep the part of the graphic you're pulling on as close to parallel to the part still on the roof. (does that make sense??) This should help you remove the adhesive portion with the vinyl portion. A little WD40 will help remove any left over adhesive and then I'd clay bar the area just to be sure its clean.
Based on my experience with a 3M clear bra, I'm forcasting some sore thumbs.
Old May 7, 2006 | 07:55 PM
Snappychip's Avatar
Snappychip
Use a heat gun that will help, then very carefully peel it, also a razor blade would help.
Old May 7, 2006 | 08:03 PM
kenchan's Avatar
kenchan
oh yah, try not to get the solution onto the weather strip felt.
Old May 7, 2006 | 08:55 PM
tdm156's Avatar
tdm156
Ruling the curves
Ouch!
Old May 8, 2006 | 09:20 AM
qwertmonkey's Avatar
qwertmonkey
I actually did the same thing. I called the dealer and they said start at a corner, and heat it up with a hair dryer.
Old May 9, 2006 | 09:14 AM
Minitee's Avatar
Minitee
I would hope that the dealer would cover that repair if they installed it just 2 months ago. My dealer is charging me $280 for that, and I'll be quite pissed if it just peels up like that.
Old May 9, 2006 | 09:57 AM
Krut's Avatar
Krut
Actually - I'm sort of relieved it happened - it's kind of boring looking on top of my car and I can't look out the roof anymore.
Old May 9, 2006 | 10:37 AM
DialM's Avatar
DialM
Just go to your dealer and tell them to take it off.
Old May 10, 2006 | 10:14 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
I told you that you wanted something perforated. But noooooooo, you didn't listen did you?
Old May 10, 2006 | 10:31 AM
Krut's Avatar
Krut
I never listen.. that's why I'm Kaptain Krutaroo.. :-)
WarEagle
R55 :: Clubman Talk (2008+)
May 3, 2019 03:00 AM
emulajavi
Dec 24, 2018 09:15 AM
Aug 24, 2015 03:02 PM
greekzilla
Aug 23, 2015 03:44 PM
iwantacooper
Aug 7, 2015 05:01 AM
