MCSa Rough Startup
Old May 6, 2006 | 08:42 AM
qwertmonkey's Avatar
qwertmonkey
MCSa Rough Startup
I have a 2005 MCSa and recently I have noticed that it is really rough starting when the engine is cold. It is spring here, to 50-70 outside. It sould like it is about to die, but it holds on and runs. Later it is fine. What could be wrong? I need an oil change here in about 2k miles, so I might wait until them to goto the dealer. If needed.
Thanks is advance,
William
Old May 6, 2006 | 12:20 PM
Bigcoyote's Avatar
Bigcoyote
Hey there,
I have had the same problem here in AZ. -and I have seen it on alot of other posts. Mine does this when they change the gasoline formula from summer to winter ( and vise versa ).
That would be my first guess - try running a different brand of high octane - it helped mine.
My 04 MCS would fire and then die or idle very rough for few minutes, then it was fine for the rest of the day.
Good luck
Old May 6, 2006 | 01:55 PM
atomtbomb's Avatar
atomtbomb
I'm currently having the same problem with my MCSa, it started immediately following a fill-up on cheap (but premium grade) gas. I'm going to run this tank through and see if I'm still having the issue.
Old May 6, 2006 | 03:14 PM
coopercrazy's Avatar
coopercrazy
I've had the same problem, but only a handful of times.
Always run 93octane.
Runs fine after a few seconds of sputtering.
Old May 6, 2006 | 03:30 PM
NealW
I believe you have the “normal” problem all MINIs have. Although there are a number of problems discussed, I believe this thread is devoted to this problem. You won’t learn how to get the problem fixed by reading the thread, but you will come to believe that you are not alone. Like Bigcoyote, I've gotten temporary relief by switching brands of gasoline.
Old May 6, 2006 | 05:20 PM
qwertmonkey
Called the dealer, and was informed that they have had OVER 20 MINIs in that week for the same problem. They dont know how to fix it. They are awating a software update from MINI.
Old May 9, 2006 | 04:06 AM
mdsbrain's Avatar
mdsbrain
Originally Posted by Bigcoyote
Hey there,
Good luck
Same
Old May 9, 2006 | 05:55 AM
fishbulb's Avatar
fishbulb
we also have this now & again on our 05 MCSa and 06 MCS.
Old May 9, 2006 | 07:52 AM
caminifan's Avatar
caminifan
It could easily be sourced in ECU/DME software. Out of curiousity (and as a baseline), have you had the DME re-program service bulletin performed?
jeri534
Nov 6, 2015 01:40 PM
jennster
Sep 28, 2015 06:19 PM
daviday
Sep 25, 2015 01:31 AM
sirfrank
Sep 11, 2015 01:36 PM
Sep 8, 2015 11:37 AM
