Clean your intake!
Old May 4, 2006 | 04:51 PM
ThumperMCS's Avatar
ThumperMCS
Clean your intake!
Just cleaned my Mini Mania CAI filter with the K&N re-charging kit...and wow is all I can say. I've only had it for about 6 months, and the filter was almost completely black. When rising it off, the water coming off of it was dirt black. Cleaned, dried, and re-oiled and its back to new! You can actually feel it breathing better...almost as dramatic as going from stock to the CAI itself. Lesson for all...CLEAN YOUR CAI FILTERS! Makes a huge difference, your car will thank you...
Old May 5, 2006 | 07:13 AM
qwertmonkey's Avatar
qwertmonkey
Where is a good place to get a re oil kit? Or is it sinpler than that?
Old May 5, 2006 | 08:05 AM
cristo's Avatar
cristo
Alliance Member
Old May 5, 2006 | 10:02 AM
mdsbrain's Avatar
mdsbrain
Typical cleaning kit is the one from Uni.
http://outmotoring.com/alta_filter_cleaning.html
Old May 5, 2006 | 10:14 AM
Motor On's Avatar
Motor On
Just make sure you get the right kind for your filter a K&N kit won't work right with a foam filter, I use the UNI kit on my ALTA, quick good results, I only manage 3 1/2 without a cleaning.
Old May 5, 2006 | 11:49 AM
retroom's Avatar
retroom
Pep Boys sells the K&N cleaning kit.
retroom
Old May 5, 2006 | 06:20 PM
kenchan's Avatar
kenchan
^^ i need to get one of those cleaners soon. my ALTA's getting
slightly brownish on the tip, not yet "dirty" but probably half way.
Old May 5, 2006 | 06:22 PM
Motor On's Avatar
Motor On
Trick I found is you can flip it over and get the other side (loosen clamprotate filter 180, and retighten) all dirty then clean it, gives you an extra few weeks before having to get the cleaning done.
Old May 5, 2006 | 07:25 PM
acitydweller's Avatar
acitydweller
Should one also consider cleaning the throttle body as part of this maintenance.
I used to do this on my Grand Cherokee 5.2ltr, Maxima 3.0 ltr and Integra 1.8ltr. Made an improvement with stock filter alone...
rtk90
Aug 29, 2019 09:08 AM
MasterShaftner
Sep 4, 2015 03:52 PM
M7Speed
Sep 3, 2015 07:48 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
