brake pedal to the floor
Old May 4, 2006 | 06:38 AM
royce's Avatar
royce
When sitting at a stoplight with the car running should you be able to get the brake pedal to touch the floor by applying A LOT of pressure or should this be impossible?
Old May 4, 2006 | 06:59 AM
vader's Avatar
vader
I think it should be impossible, unless you apply enough pressure to bend something.
Old May 4, 2006 | 07:17 AM
pdflint's Avatar
pdflint
The brake pedal dropping to the floor usually indicates a fluid leak, a master cylinder problem or air in the system. Check the fluid level in the master cylinder reservior. If it is rapidly dropping when you pump the pedal, you most likely have a leak. If the level remains fairly constant, then air most likely has entered the system and the brakes need to be bled.
Have you had work done recently on the brake system? Also, if the fluid level in the master cylinder reservoir has dropped below the minimum level due to pad wear, then air can be pumped into the lines causing a mushy feel in the pedal.
Old May 4, 2006 | 08:17 AM
JDR's Avatar
JDR
I had this happen in an old car. If it is completely random, chances are pretty high that you should check the master cylinder. Have you done any work on your breaks very recently?
Cheers and good luck
Old May 4, 2006 | 08:27 AM
Mini Works's Avatar
Mini Works
The only way this coud happen is if you have a leak in the system or a bad master cylinder,
otherwise, the pedal should go down, until you reach maximum pressure, and stay steady.
theblackfalcon
Oct 11, 2015 09:49 AM
thebordella
Aug 31, 2015 01:37 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
