Hubcentric Rings
Old Apr 27, 2006 | 10:59 AM
1QKMNIS's Avatar
1QKMNIS
Hubcentric Rings
I just got some new wheels and am planning to have them mounted on Friday with some KDW's but I still need some hubcentric rings. Now the guy wrote me and said the specs on the wheels were 54.1mm Inside Diamter and 73.1 Outside Diameter. So what size hubcentric rings do I need? I was reading the Mini was a 56.1mm Inside diameter, does this mean im screwed? Thanks.
Spencer Hall
Old Apr 27, 2006 | 11:27 AM
simplygriff's Avatar
simplygriff
Coordinator :: Tar Heel MINI Motoring Club
Something's not right there... The wheel should only have one diameter. There's only one hole.
Edit: Actually that smaller hole is probably where your center cap would go. Chances are you need a 56mm to 73mm hub ring.
-G
Old Apr 27, 2006 | 03:12 PM
Mini Works's Avatar
Mini Works
56mm is the size of the shoulder on the hubs.
73mm is the hole on the wheel
Victor
vulkandino
Oct 31, 2015 08:29 PM
Alpha Motoring
Oct 1, 2015 10:30 AM
patsum
11
Sep 30, 2015 02:20 PM
JAB 67
Sep 29, 2015 01:34 PM
Nicefeet
Sep 24, 2015 06:53 PM
