Forged vs cast wheels- what are the advantages?
I am trying to decide what wheels to get for my MSC. I like the Centerline forged wheels, and they are currently available at great overstock prices. The Centerline site says that forging produces strong yet light wheels. The 17" Storm wheels are 13 pounds with a polished metal finish. However, I have read elsewhere that forged wheels may be more fragile for road use. Are cast wheels better for road use, or is it just a matter of the particular wheel or brand?
Other wheels that I am considering are Team Dynamics Pro Racing 2. These are cast, are about 16.5 pounds and have a painted finish.
The Team Dynamics wheel is also available in a 16" size, which I am considering. The Centerline wheel is not available in 16" size.
Which would you choose?
Team Dynamics Pro Racing 2 in silver- $176 each
Centerline Storm, in polished metal finish- $159 each including shipping
Team Dynamics Pro Racing 2 in silver- $176 eachCenterline Storm, in polished metal finish- $159 each including shipping
forged wheels are generally the strongest and the lightest, but not all forged wheels are equal. i have herd some things about centerline wheels cracking. this could be due to their heat treatment. i haven't really heard anything negative about team dynamics, this may be the clue in your decision. but i would do some research yourself.
here is a link from the tire rack on wheels, it should give you all the information you need to know about wheel construction.
Generally speaking, a forged wheel is going to be lighter than a cast wheel of an equivalent diameter and width, and stronger than a cast wheel of the same weight or close to the same weight. So again generally speaking, a high quality forged wheel will cost more, be stronger "per lb" and lighter "per inch" than the cast wheel. The reputation for fragility arises in part from the everyday use on potholed streets of extremely light wheels meant for racing on smooth surfaces. I think that the trick is to go light w/o going too light, sticking with a quality manufacturer, being realistic about how and where you drive, and understanding that unless you luck into a great sale you're going to pay more
Forged wheels are lighter for a given strength and their extra strength may provide more clearance for brakes or suspension components because the metal doesn't have to be as thick. Many people will replace stock cast wheels, with larger diameter, forged wheels, with rubber band tires on them. Those tires don't offer the rim protection of most OEM tire sizes. Another possible problem is, if the new wheel is wider, relative to the tire width, then there is less protection from side impacts, like curbs, as well.
Generally speaking, all else equal, a forged wheel will let a car, accelerate faster, stop quicker, handle better and get better gas mileage.
Thank you all for your replies. The Centerline wheels are a bargin now- they are normally about $350 per wheel, but because of an overstock sale, are available for $159. I have read, as mentioned by Williemcd, of people getting cracks in their Centerlines- if that does happen, they would be no bargin. I do plan to use 205/45/17 non-runflat tires, so I will have some cushioning. I think that ultimately, I would be taking a chance on the Centerlines. I like the finish better on them, but they would be nice looking pieces of junk if they do crack. Anyone out there with experience with Centerline wheels?
The other option is to look at wheels that cost a little more than these to get a higher quality forged wheel. I do not know your budget..
But, purchase the best rubber you can afford first, then buy the best quality rim that you can afford second..
Good luck in your search
OK technical mumbo-jumbo here:
metallurgically speaking, the differences really are in the grain structures. castings tend to have voids, large crystals (meaning less strength), they have to have stock available to be machined because there is a lot of porosity near the surface, and then machining also interrupts the fluidity of the grain. With forging, the crystalline structure is more compact (stronger, but slightly more fragile), it is also to make forgings to a near-net shape, thereby reducing the amount of machining necessary. The downside to forgings is the up-front investment. Metal dies are much more expensive than sand.
I went with Centerline Storm 17x7's with 215/45-17 Goodyear Eagle F1's for my 06 MCS. Already have the rims and tires, picking the car up next week and they are going on day 1. Jegs.com has the Storm in 17x7 for $159.99 including shipping - everyday price.
There are tons of wheel makers out there,, Centerline has been around for decades and built their resume on racing. I have owned multiple sets of Centerline rims on various cars and have never had an issue with them. Going with Centerline was the safe play compared to going with a brand I had never heard of.
Cracked Centerline RPM Wheels....
I just saw this thread or I would have chimed in sooner.
I am on my second set of the Centerline RPM wheels. These are the versions that have had the cracking issues. The earlier versions of this wheel had a pocket machined on the back side of each spoke to lighten the wheel. This is the area that they tended to crack in. I had a crack appear on only one spoke of one wheel and Centerline replaced all four wheels with the new version that does not have the lightening pockets machined in the spokes. I did have to pay for the wheels to be shipped to Centerline but the tire shop I worked with pickup up the rest of the costs for mount and balance.
CAUTION: They are still selling the old style RPM wheel for a reduced price on their website.
My 16" Volk CE28N's are forged, and have seen their share of street abuse (for amost 3 years), w/o any issues whatsoever. They are 10.75 lbs, and while light, they are very durable...
They are more expensive, but I didn't feel dramatically so. After shopping around, I got a set of 4 for a total of $1,200 something, or about 300 each (local pick-up and cash payment).
The Centerline RPM's, at least at that time, didn't offer 16's... but the if I would have gone with their 17's, the price delta was only like one wheel, or a couple hundred or so bucks, maybe 300.
I've known a few since that have had hairline cracks with the Centerlines, which just made me feel better about spending a little more initially. Plus, I really wanted 16's, not to mention their really light weight.
The WW race BBK (more weight loss) fits beautifully right under these, with zero spacers!
Centerline Hub Centering Rings? wth?
Hey guys, if you buy the Centerline RPM wheels that are on sale on their site now, be careful. I just bought a set of 17" RPM's and they don't ship with hub centric rings so they don't balance properly on my mini. The wheel hub is something like 76.62mm and the mini hub is 56.10mm. That's a pretty big gap, almost a inch, so hub rings are needed. I've balanced them twice and right now my steering wheel still vibrates nicely above 50mph.
Centerline has told me they don't have or sell hub rings. My only other option now is to get custom hub rings made or send the wheels back to centerline.
Anyone else have similar issues??
Maybe they should change their name to Off-Centerline.
-James
2005 Chili Red Mini Cooper S
-James
IQRaceworks
53
Jun 28, 2024 07:29 AM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
F55/F56 New Clubman AT is the 8-speed
Sailorlite
Oct 1, 2015 06:46 AM
