Power Steering failed and came back.
Old Apr 25, 2006 | 12:34 PM
orb451's Avatar
orb451
Hello all,
I drive a 2003 MC and about 2 weeks ago I went out one morning, started up the car and noticed it was nearly impossible to steer. Realizing that the power steering was not working, I drove to work anyway. I worked the whole day and when I came out that afternoon and started the car up, my power steering was working again.
Everyday since then, my power steering has been working fine. When I turn the steering wheel at low speeds I do not hear any creaking/cracking sounds as some have described as indicative of a rack and pinion failure.
I was just wondering if anyone else had experienced a power steering failure and then revival... and if it was intermittent, what were the intervals? Did it ever fail completely? I would think that if the power steering pump failed, it would fail outright and that would be that. Also, I would think that if it was on it's way to failure, it would be acting up a lot more frequently.
I live in Los Angeles and the weather's been crappy every few days, is it possible for a power steering pump to have a temporary failure due to water/electrical short, or is that just wishful thinking?
Any advice or help would be appreciated, I checked our Owner's Manual and found no helpful info on Power Steering.
Thanks!
orb.
Old Apr 25, 2006 | 02:48 PM
NeilM's Avatar
NeilM
Since the Mini's PS consists of an electrically driven hydraulic pump, I'd suspect an intermittent bad power connection to its motor. The first thing to do would be to check all the electrical connectors in the PS motor circuit.
The other possibility is foreign object ingestion of the PS motor's cooling fan, a common problem.
Neil
05 MCS
96 M3
Old Apr 25, 2006 | 02:51 PM
orb451's Avatar
orb451
Great, thanks Neil I'll check the connections and see what I can come up with.
Old Apr 25, 2006 | 02:59 PM
carletta's Avatar
carletta
I have an '05 and my power steering stated to go and was intermittant for a few days, before it finally went out altogether. New power steering pump fixed it.
Old Apr 25, 2006 | 03:12 PM
AAAMINI's Avatar
AAAMINI
Mine was the same as carletta's, but it took it a few weeks to die. It would never do it at the dealer so I had to wait for it to die to bring it in. It was off and on just as you describe, usally when it sat for more than an hour it would come back. The dealer put in a new one, and we have been good since...
-Andy
Old Apr 25, 2006 | 03:33 PM
orb451's Avatar
orb451
Well, hopefully it's just a loose connection or something that was caught in the fan and fell out on it's own... But I'm getting quotes for a replacement pump + service... between $500 - $600.
Oh what fun!
I guess that's not too bad for 60K miles on it though
Thanks again for the input!
orb.
Old Apr 26, 2006 | 05:35 AM
NeilM's Avatar
NeilM
Yeah, that's the option we all hoped wouldn't have to be mentioned!
Neil
05 MCS
96 M3
Old Apr 26, 2006 | 05:57 AM
gooner's Avatar
gooner
I had the same problem. The seals in the pump went then a few months later the motor failed,thankfully all under warranty.
Old Apr 26, 2006 | 06:03 AM
boognish's Avatar
boognish
When the power steering failed on my 2003 MC (with about 35,000 on the odometer) one of the symptoms was that all the guages on the dash lit up and the coolant temp guage was pegged to the overheat (although the car DID NOT overheat at all...my car had the dealer recall "fix" where the PS fan and the radiator fan were put onto separate circuits) but the electric PS motor would NOT STOP RUNNING, even when the car was off and key was out. After about 2 hours, it stopped on its own. Next day, towed to the dealer, and oddly, this is all they wrote on the service slip: "Power steering motor very loud; replaced under warranty."
Whatever... as long as it fixed it, and it seemed to, since I've put on about 10,000 more miles since then without a problem.
Good luck,
-boognish
Old Apr 27, 2006 | 10:21 AM
BigBen's Avatar
BigBen
I have 63K on my 03 Dooper and my power steering fluid is leaking, I am thinking it is just a seal or something because i have yet to loose my power steering
Old Apr 27, 2006 | 11:45 AM
Rick-Anderson's Avatar
Rick-Anderson
I had the same problem and they replaced my steering pump
Old Apr 27, 2006 | 02:48 PM
BigBen's Avatar
BigBen
heh heh...........i said i drive a Dooper...........sorry, a COOPER is what i meant............no offense
Old Apr 27, 2006 | 02:49 PM
BigBen's Avatar
BigBen
thanks for the info Rick-Anderson. I will definately consider replacing it if i do not find any leaks
Old Apr 29, 2006 | 11:20 PM
UnMini's Avatar
UnMini
the exact same thing happened to me until the PS died completly and I had to replace it. the old one was leaking oil from the top I posted some pics on another tread in case your interested
Old Apr 30, 2006 | 08:37 AM
BigBen's Avatar
BigBen
UnMini,
Could you post the link to the thread you mentioned, thx for the info
Old May 1, 2006 | 06:37 AM
Rick-Anderson
I should have said that there were no leaks or anything. The dealer told me that they found the problem with computer.
Old Sep 26, 2006 | 06:28 AM
Sarcux's Avatar
Sarcux
I took my car mudding a bit on Friday, and everything was fine all weekend. However, last night as I pulled into my neighborhood the steering started to intermittently fail.
I have the cooling fan off the car now, it did have some mud caked in it. Classic quoted me $700 for a new pump, so I'm going to try and sort it out myself. It works occasionally, then dies.
Old Sep 26, 2006 | 06:32 AM
Sarcux's Avatar
Sarcux
Might I also say that it is making absolutely no odd sounds. The electric motor just isn't always running when you turn the wheel.
Old Sep 26, 2006 | 01:39 PM
jrh0558's Avatar
jrh0558
My PS was intermittent for a few days before I got to the dealer to have the pump replaced. I had a few hundred miles left on my warranty, so I was lucky. It didn’t look that hard to replace, if you wanted to go that route. Don’t know how much just the pump would cost.
Good luck!
Old Sep 26, 2006 | 02:30 PM
Sarcux's Avatar
Sarcux
I've learned the hard way that I have no right to work on my own car, hehe.
Old Sep 27, 2006 | 11:08 PM
1QKMNIS's Avatar
1QKMNIS
Yep
Exact same issue with my 04 MCS at about 30,000 miles and a new power steering pump fixed it.
-Spence
Old Sep 28, 2006 | 12:30 PM
Sarcux's Avatar
Sarcux
My problem turns out to be a $1200 one. The wiring clip that attaches the pump to the harness broke sometime back, and water/salt/goo has gotten in there, corroded everything, and shorted out the harness and the pump. JOY!
I need a drink. Or two. Or 50. And a hot chick to soothe my pains.
Old Sep 28, 2006 | 04:14 PM
Crashton's Avatar
Crashton
Before I spent $1200 I'd have a go at cleaning things up myself. If it doesn't work, then well heck what are you out an afternoon? If it does you've saved big $$$$.
Old Sep 29, 2006 | 09:38 AM
sequence's Avatar
sequence
Yup. The seals inside the rack assembly tend to blow out, causing the boot to fill up with fluid (that's where it's going.) Had the exact same problem with my 05 S. Dealer fixed it and gave me a 4 wheel chassis alignment under warranty. This is huge problem with the 02-06 Coopers, and one reason why they're going to an all-electric steering system in 07.
Old Sep 29, 2006 | 10:30 AM
MINIyegor's Avatar
MINIyegor
It happened to me too, on the freeway. I had the car towed to the dealer, but it was functioning OK, so they didn't do anything. Then it happened again. I went back and they replaced it without questioning, saying they should've done it when I sent the car for the first time.
Manny_cooper
Sep 10, 2015 11:09 AM
bansasn
15
Sep 4, 2015 01:24 PM
Aug 25, 2015 09:33 AM
coachvminis
Aug 25, 2015 06:58 AM
minipopkart
Aug 13, 2015 05:22 AM
