new horn installation wiring help
Old Apr 9, 2006 | 04:48 PM
edgab28's Avatar
edgab28
guys, just a question, i purchased a stebel nautilus and changed the stock horns. just wondering how do i add an additional relay to it? i know that the stock horns have a relay already, but my electrical current is fluctuating using only the stock relay. how do i add the relay that came with the horn? the existing horn wires are now connected to the new horn. how would i ground the additional relay and which wire will i use? and do i need to ground another fuse? or will a change the stock 15a to the recommended 20a? need help.. thanks.
Old Apr 12, 2006 | 06:36 AM
OKeefe's Avatar
OKeefe
maybe this will help ....
http://http://members.***.net/bjokeefe/hornwire.doc
Old Apr 18, 2006 | 08:28 AM
SheaJeff's Avatar
SheaJeff
This may help as well. I installed the Stebels as well. PM me with any quesitons.
https://www.northamericanmotoring.co...ad.php?t=58084
Old Apr 18, 2006 | 10:23 AM
kenchan's Avatar
kenchan
wat ever you do, don't start changing the fuse values in the fusebox.
just wire up the relay and use the factory horn wire as your trigger.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Super Coop
Aug 17, 2015 05:09 PM
