who can tell me how big a job replacing a cam is
Originally Posted by SpiderX
I am thinking of putting the race cam in my engine without any knowledge of the scope of the job.... is it 3, 5, 2 hr labor?
piece of cake, just make sure you rotate the motor so the mark on the cam gear is up, you will need a jig to hold the gear while you take the cam gear bolt out. make sure you mark the timing chain with a paint marker on the cam gear tooth that is marked. use assy. lube on everything, and follow the torque specs and order of torqueing the bolts.
note: when in doubt read the manual completley!!
cheers
Originally Posted by willy69
hey spider,
cheers
cheers
use a zip tie to to keep the cam gear and chain in order. ( zip the chain to the gear before taking out the bolt ) For the tensioner I have a tri-angle wedge I push in between the 2 sides of the chain to hold the tensioner open so I can pull the gear up enough to get it on and off.
Should take 2 - 3 hours or so
thebordella
Aug 31, 2015 01:37 PM
minipopkart
Aug 13, 2015 05:22 AM
