New Helix 15% Twin-Cone 380cc injectors
Old Mar 28, 2006 | 10:26 AM
Helix13mini's Avatar
Helix13mini
We are proud to introduce the first injectors with OEM nozzles that have correct spray patterns for the MINI's head. These injectors are manufactured by Bosch and flow 380cc/min., and have 15% dual cone spray pattern.
Why a twin cone pattern? because the engineers at MINI designed the OEM injectors to flow directly at the intake valves, not at the central bridge. Here's a shot of the intake ports of a MINI head. Sorry for the photography and file size...
The above picture shows a stock MINI intake port in detail. A central bridge is clearly visible. This is where the main inlet port becomes split to direct air (and fuel) towards the intake valves. The correct injector type for this inlet configuration is one where the injector nozzle sprays a precisely split amount of fuel directly into each port and onto the back of each intake valve. An injector that sprays a single narrow fuel cone will wet the metal walls and causes fuel to dribble into the combustion chamber. Tuning/holding precise air/fuel ratios is thusly complicated.
Here's a rather out-of-focus clip of a single stream, aftermarket injector's spray pattern (no worries, I made the clip short):
http://helix13.com/pics/380ccinj.wmv
Now here's a clip of the new helix 15% split stream injectors:
http://helix13.com/pics/helixbadassinj.wmv
We have these injectors in stock, and ready to ship for $360 per set. Please don't hesitate to call or email if you have questions.
IQRaceworks
53
Jun 28, 2024 07:29 AM
NYMADMINI
Dec 14, 2016 02:33 PM
randeez
Oct 5, 2015 09:23 AM
WhinyR53
Sep 30, 2015 07:36 AM
dutchhome
Sep 30, 2015 07:17 AM
