Help With OBD Code P1237
Old Mar 19, 2006 | 07:07 AM
Cosmic Purple's Avatar
Cosmic Purple
Peace,
Please help. I loaned my other OBD device to a fellow mini driver. The service engine soon light came on after some jerking motions. The code reads P1237. Thanks.
Old Mar 19, 2006 | 08:46 AM
Barnabas's Avatar
Barnabas
Secondary upstream manifold air pressure sensor low input. Check connections on your map sensor to make sure it's not loose. You might have to get your map sensors replaced
Old Mar 19, 2006 | 08:49 AM
Motor On's Avatar
Motor On
https://www.northamericanmotoring.co...0&postcount=17
hope this helps
Old Mar 19, 2006 | 09:29 AM
Cosmic Purple
Thanks. This helps greatly.
Old Mar 19, 2006 | 10:16 PM
rottenron's Avatar
rottenron
p code 1237
secondary upstream mainfold air pressur LOW Input
The first thing I would think is a vacuum leak -EGR-PVC-
Is the code a hard code? meaning it will come back after cleared.
Old Mar 19, 2006 | 10:32 PM
Barnabas's Avatar
Barnabas
I don't believe so. Should go away after 3 key cycles once fixed
thadscottmoore
Jun 4, 2021 07:19 AM
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
RocketUSA
Sep 15, 2015 07:45 AM
mtwaddle
Sep 13, 2015 08:10 PM
