Side marker sticking out from fender
Old Mar 15, 2006 | 04:40 PM
ArmyDog's Avatar
ArmyDog
Coordinator::Asia
My left front side marker (the top portion) somehow popped out of the fender flare recess. It is sticking out about 1/4". I have tried to push it back in by hand but it will not seat. I looked in my Bentley manual and it does not show how to remove or install the side markers. Anyone with info on how to fix this small problem please let me know. Thanks!
Old Mar 15, 2006 | 04:42 PM
MSFIT's Avatar
MSFIT
there are small 10mm metal "nuts" they like cut into the plastic piece as you tighten them down.
this explains it
http://www.allproducts.com/metal/wil...444185632.html
Old Mar 15, 2006 | 04:46 PM
MSFIT's Avatar
MSFIT
btw I love your wheels!!
ArmyDog's Avatar
ArmyDog
Coordinator::Asia
How do I access the nuts? From the inside of the wheel well under the plastic cover?
Old Mar 15, 2006 | 04:55 PM
MSFIT's Avatar
MSFIT
I think the easiest way would be to pull your bumper off. You could do it with the wheel liner out if you removed your rim, but taking the bumper off is not very difficult at all.
Old Mar 15, 2006 | 05:17 PM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
If I recall correctly there are only seven screws that hold your bumper on. Underneath are 3 phillips head screws, When you look under you bumper, it's not the set of screws closest to the front, but the second row of screws.
open the bonnet and there are 2 torx screws that screw into the frame and there are 2 plastic hex head screws one on each side of the bumper towards the outer edge. They are holding a tension type clip. Those are accessible from inside the wheel well.
MSFIT is correct in saying that it is easy, and you don't need to remove the wheel. Just make sure you have a ratchet extension to access the screw in the wheel well.
Sorry I don't remember the torx or the hex sizes.
I don't think I missed anything. I hope.
Old Mar 15, 2006 | 05:26 PM
ArmyDog's Avatar
ArmyDog
Coordinator::Asia
Thanks for your help guys. Sounds like a good rainy day project in the garage. Bentley's does have the instructions for the bumper removal.
Old Mar 15, 2006 | 05:38 PM
MSFIT's Avatar
MSFIT
except its a little bit different, aero kit front bumper
under the front you will see what four things that look kinda like bolts or something but they are plugs, just get a flat head screw driver behind them and pop them out
Then one phillips head in each wheel well liner
then torx where the hood meets the bumper (bottom arrow)
then 10mm bolt (top arrow)
Old Mar 15, 2006 | 05:43 PM
onasled's Avatar
onasled
As far as I know there are no screws or nuts holding these things on, so you don't need to tear the car apart to get to it. It's just a clip on one end and a compression fitting (plastic tab pushed in and held by a rubber grommet) on the other.
Get something to pry out the end where the S is. It will just pop out. Once that end is just freed, then pull it out sideways, toward the back of the car. That will unclip the end where the light is. Then unplug the wire if you need to.
Old Mar 15, 2006 | 05:49 PM
MSFIT's Avatar
MSFIT
Get something to pry out the end where the S is. It will just pop out. Once that end is just freed, then pull it out sideways, to the right. That will unclip the end where the light is. Then unplug the wire if you need to.
I'm pretty sure he's talking about the light in the front bumper, in the actual arch.
Old Mar 15, 2006 | 05:55 PM
golden_child
I need to pay more attention to the picture in his sig. And I didn't know the stock bumper and areo bumper had different mounting points
Old Mar 15, 2006 | 06:02 PM
onasled's Avatar
onasled
oooppps , your right.
cawwwtun
May 3, 2016 08:03 AM
Ollie625
Aug 28, 2015 12:05 PM
Aug 24, 2015 02:47 PM
OutMotoring
Aug 6, 2015 09:32 AM
