Navigation & Audio Broken nav when updating.
Old Mar 6, 2006 | 11:36 PM
barbaloot's Avatar
barbaloot
I was trying to update my nav to SW v26. I followed the instruction and ejected the DVD then inserted the update CD. It said it was reading it, for like 2 seconds. Then the screen went blank. And didn't do anything for 15 mins. Never asking me if I wanted to install the update. And now I just have a blank screen, no computer, no nav.
Any ideas?
geno.
Old Mar 7, 2006 | 12:42 AM
rkw's Avatar
rkw
The troubleshooting section of the Technical Service Bulletin for v26 suggests that you have a bad software CD. Are you able to eject it? If so, put it in your computer and describe generally what is on the disc (there should be a lot of folders and files).
Describe the steps you took to create the v26 software CD.
Old Mar 7, 2006 | 05:08 AM
mdsbrain's Avatar
mdsbrain
Double-check the update CD was created correctly. Then put it back in. You should be able to correct the Navi.
Old Mar 7, 2006 | 08:45 AM
barbaloot's Avatar
barbaloot
I used Alcohol 120%. Downloaded the Rar file. Unstuffed it. Went into disc image wizard in A120%. Found the image file in the unstuffed Rar file. And burned it at the slowest speed 4X.
Below is a shot of the files on the burned CD.
Old Mar 7, 2006 | 08:52 AM
mdsbrain's Avatar
mdsbrain
Right, just burn the image to the CD.
Please check my blog for more details.
http://mdsbrain.com/mini/?p=46
Old Mar 7, 2006 | 09:09 AM
barbaloot's Avatar
barbaloot
That's what I did. Maybe I will try burning another one. I also have a friend sending me the one he used so I know that it's a disk that will work.
Old Mar 7, 2006 | 09:53 AM
mdsbrain's Avatar
mdsbrain
Once the update starts the system will reboot leaving the screen black for a few seconds. It will then ask you to update the software. Strange this didn't work for you
Please take into consideration that your car must be a newer MINI (04+) to use this update and use DVD Navi discs.
Old Mar 7, 2006 | 09:58 AM
barbaloot's Avatar
barbaloot
Yeah the "Do you want to undate press OK" never came up. And disk was in the drive for 15 mins.
And yeah I have a 2005 Cabrio with MKIV DVD based nav.
Old Mar 7, 2006 | 09:59 AM
mdsbrain's Avatar
mdsbrain
weird... I am hopeful the disc from your friend works. The difference is night and day from the previous versions.
Old Mar 7, 2006 | 10:06 AM
rkw's Avatar
rkw
Hopefully burning a new disc or using your friend's will work. I did exactly the same steps you did, and mine installed flawlessly; also the contents of your disc look correct.
Old Mar 7, 2006 | 10:07 AM
barbaloot's Avatar
barbaloot
Yeah this is driving me crazy! Thanks to all of you. I am going to retry tonight. See if I can burn it slower. Use a higher quality blank disc. yada yada yada.
geno.
Old Mar 7, 2006 | 12:49 PM
barbaloot's Avatar
barbaloot
Quick question before I go home and try this. Which do you guys think would work better? Nero? Alcohol 120%?
Old Mar 7, 2006 | 02:14 PM
rkw's Avatar
rkw
geno, with the luck you're having, you better do both! Seriously though, I think Alcohol Software is the originator and owner of the .mdf and .mds file formats, and it is what I'd start with.
Old Mar 7, 2006 | 03:46 PM
HowardPM's Avatar
HowardPM
I
had the same issue when I flashed my v26 version, it turned out some how the burning program didn't name the CD correctly (the label). To fix it I had to reinstall V25, then remake the v26 one. All is good.
Old Mar 7, 2006 | 04:05 PM
barbaloot's Avatar
barbaloot
Anyone know what the disk name should be?
Right now my the disk is called NAV_SW
Old Mar 7, 2006 | 08:14 PM
barbaloot's Avatar
barbaloot
Re-burned v26 on a better CD-r and it worked great! Wow looks amazing!
Old Mar 7, 2006 | 10:25 PM
rkw's Avatar
rkw
Congratulations! I can imagine the panic you must have felt yesterday.
Fordgt4
Oct 10, 2015 10:42 AM
B1mm3r101
Oct 1, 2015 06:22 AM
TurboMike
New York/New England
Sep 28, 2015 08:12 PM
daviday
Sep 25, 2015 01:31 AM
