Road Racing Discussion Interested in taking your MINI road racing? Find out what you need to do to get your MINI ready!
Slotted brake rotors
Old Feb 28, 2006 | 06:33 PM
J Propane's Avatar
J Propane
Anybody out there has a good source for slotted brake rotors?
Old Feb 28, 2006 | 07:01 PM
TonyB's Avatar
TonyB
I believe TCE can hook you up... I'll see if I can get Todd over here. FWIW, from what I picked-up from him, some, if not all of the benefits of slotted rotors can also be had simply with slotted pads. I'm sure he can confirm...
Old Feb 28, 2006 | 07:22 PM
cooper99's Avatar
cooper99
I recommend to buy some D/S rotors off Ebay. $200 dollars for 2 front Brembo rotors and 2 rear Zimmermans is pretty much a steal. There are already several threads about the reliability of the D/S rotors off ebay, but I have had them on my car for almost a year and had the rotors glowing orange several times and they still appear to be fine. Even if one were to crack, I could buy 2 brand new ones off ebay for $100. Despite some peoples opinions, I think its a small risk well worth taking.
Old Feb 28, 2006 | 07:36 PM
J Propane's Avatar
J Propane
cooper99, Thanks for the tip!
I assume that by D/S you mean drill/slotted ?
I am actually looking for slotted only. Drilled rotors do crack easily under track usage.
Old Feb 28, 2006 | 07:41 PM
toddtce's Avatar
toddtce
Slots can aide in pad outgassing and 'wiping' of the rotor surface. All good for most competition use. On the flip side this can lead to increased wear, dust and noise for the street user.
Slotting of pads can help in this and is done to vent the pad as well as allow for expansion of the pad without cracking.
I do not offer stock sized rotors so I cannot be of any help beyond some input to what and why. Keep in mind that any change to rotor surface will not increase rotor torque or thermal capacity. By far however the addition of slots, a good set of pads and some SS hoses is the best choice for those who do not want to fund the BBK.
Old Feb 28, 2006 | 08:40 PM
J Propane's Avatar
J Propane
Todd,
Thank you for the great technical expertise. This confirms why I want slotted-only rotors.
Old Feb 28, 2006 | 08:43 PM
ScottinBend's Avatar
ScottinBend
I got a set of Powerslots from JSC Speed for a very good price. Check him out.
Old Feb 28, 2006 | 08:45 PM
OldRick's Avatar
OldRick
Powerslot rotors at Mini-Madness: http://www.mini-madness.com/index.as...PROD&ProdID=84
Old Feb 28, 2006 | 08:47 PM
DrkSilvrMini's Avatar
DrkSilvrMini
Tire Rack also has them
molala
Oct 2, 2015 01:53 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
