NorCal MINIs A club for Northern California MINI Cooper enthusiasts. Visit our club site at www.norcalminis.com
Gauges
Old Feb 25, 2006 | 11:17 AM
MiniKiwi's Avatar
MiniKiwi
Gauges
Does anyone have the gauges that BMW sells that attach to the Tach? I'm trying to find out if they are 52MM... long story short, I have Nav and want to see if they fit in the bracket thats made for under the toggle switches... as I'd like a better set of gauges than voltage and oil temp...
If anyone has them or knows of someone who's done this?
Old Feb 25, 2006 | 08:03 PM
WEEGIT's Avatar
WEEGIT
I've got them. They're made by Stewart Warner and are 2-1/6" diameter = 52mm. I'm actually replacing them with Autometer gauges for boost and oil pressure. I'm also looking for a clean way to mount 2 more gauges (water temp and oil temp) above them. Something like the ALTA pod, but for 4 gauges. Maybe I'll have to have it custom made. Know of anything? As far as I know, the S/W gauges for under the toggles are the same size and black, not silver.
Old Feb 26, 2006 | 09:21 PM
COR BLMY's Avatar
COR BLMY
Chehaw about 3
Take a look in my gallery I have 3 gauges
Auto meter Ultra lite
Boost
Oil Press
Water temp
Old Feb 26, 2006 | 09:40 PM
WEEGIT's Avatar
WEEGIT
Boost
Oil Press
Water temp
Logical setup if you have duel steering column gauges.
Actually, the OEM gauges for the console are VDO, and I think black. I guess so there is less contrast with the surround. I can't figure out why these particular gauges and two companies were selected.
I may stay with the OEM gauge holder at the steering wheel and just change out the gauges, for boost and oil pressure. Maybe then buy just the OEM console holder and put water and oil temp gauges there. Decisions decisions
Old Feb 26, 2006 | 09:48 PM
COR BLMY's Avatar
COR BLMY
I saw 1 fellow at last years "Big Mini Day" and he had a tandom factory set up.
He welded a 2nd set with risers so that they were about 3 inches above the other 2.
It looked OK and did keep them in line of sight.
Old Feb 26, 2006 | 10:26 PM
mistro's Avatar
mistro
bpago,
How did you mount the boost gauge between the Tach and Speedo. That's what I want to do! TIA Michael
Old Feb 26, 2006 | 10:32 PM
not-so-rednwhitecooper
Have you thought about A pillar mount?
I have 4 gauges on mine now and still have room for 1 more.
Old Feb 26, 2006 | 10:34 PM
Sam's Avatar
Sam
3 gauge pod
Boost
Oil Press
Water temp
That's almost exactly what I want to do - except I would like to mount the three gauges on the left hand side windshield pillar. Some one had a set for sale recently - but the interior picture was of a right side drive MINI. Passed because I didn't know if it could be flipped for the left hand side
Old Feb 26, 2006 | 10:47 PM
COR BLMY's Avatar
COR BLMY
I custom fabricated a flat plate that attaches to the 2 large screws (spacers and longer screws needed) on the back of the stock Speedo / Tach.
The gauges are usyaly "flush mount" but in this case you use the 2 studs on the back as the mounts.
bahman
Feb 14, 2016 10:29 AM
Doc Pain
Oct 28, 2015 07:09 PM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
aldito2
Sep 30, 2015 10:44 AM
