Suspension Corner Balancing
Old Feb 5, 2006 | 07:21 PM
K9MINI's Avatar
K9MINI
Corner Balancing
I am taking the plunge and going with Bilstein PSS9 Coilovers. I have heard of corner balancing but know nothing of what it is. Is this a pre-loading of the suspension? Any help would be great.
Old Feb 5, 2006 | 08:47 PM
kenchan's Avatar
kenchan
wooo... another long thread coming.
k9mini- yes, it is preloading the coilovers until each corner has its ideal
weight distribution so the car sits flat horizontally and with watever
rake you want forward/aft to dial-in your car's dynamics. it's quite
involved and I think Dr.Meb is typing away as we speak for a very
thoruoughghghghh, explanation.
Old Feb 5, 2006 | 08:57 PM
K9MINI's Avatar
K9MINI
Thanks! I knew it was going to be a long one! I am going to also need Onsled on this one.
Old Feb 5, 2006 | 09:00 PM
ScuderiaMini's Avatar
ScuderiaMini
yeah, Onsled is a book himself, can't suck enough information from him
Old Feb 5, 2006 | 09:02 PM
Scooby03's Avatar
Scooby03
Soon to be done. Another thing on the to do list.
Old Feb 5, 2006 | 09:08 PM
Coopernicus's Avatar
Coopernicus
I'm not "Dr. Meb" or Onasled, and haven't done this in a few years, so please don't flame me if I get a detail wrong here or there - I am only trying to help.
It involves using a set of car scales that have four scale pads - one to be placed under each wheel, that are joined to a common console that shows the weight supported by each independent wheel. It can show (diagonal) cross-weight, or the sum of any combination or ALL of the individual weights. This is the same type of scales used in impound at SCCA Nationals, National Tours, ProSolos, etc.. But the better performance alignment shops have them and/or you can buy a set from RacerWholesale and other race shops. This process needs to be done on a perfectly level and even surface to ensure accuracy.
In its simplest form, your intent is to use these scales to balance the car's weight Diagonally (LF to RR, RF to LR), Front to Back and Left to Right as accurately as is practical. You do this by adjusting the ride height of each shock individually while watching the weights move around. As you lower one corner, you are essentially 'Tilting' the car towards that corner, thereby INCREASING the percentage of static load (weight) that corner carries.
You start by setting each coilover's ride height so the car is even and level, with the basic amount of drop from stock that you want. Measure the arch height-to-ground on each wheel well, adjust each shock until the car is level, then establish the rake that you want (if any). Make sure the suspension does not have a chance to bottom-out due to lack of travel, because if you set it too low, it will hit or ride on the bump-stops and induce what is called bump steer, a dangerous condition that could cause you to lose control. Run-in the new springs with this basic configuration locked down for a bit before messing with the scales to make sure they are fully seated and settled-in.
Then, when you put the car on the scales, make sure the suspension is loaded like normal (and can move freely - not in any bind) and plan for a few hours of tweaking...
Obviously, given the front-heavy weight bias of the MINI, there is just so much you can do to level the weight F-to-R by changing the ride height of coilovers. But, you can still send a little weight to the back without making the front all jacked-up and the rear scrape the ground (in other words, use some common sense with your settings).
To do cross-weight comparisons, set the scale controller to display one front and one rear (the rear opposite side as the front, as shown below) and adjust each corner's ride height so that the LF+RR pair supports the EXACT same percentage of weight as the RF+LR pair WITH the driver sitting in the driver seat just as the car would be driven. 50% is ideal, of course.
LF . . . . . . RF RF+LR=50%
. . . . .X
LR . . . . . . RR LF+RR=50%
This is very over-simplified, and there are subtleties to account for in each unique suspension design. But it should give you an idea of how to get started. Once you are satisfied with the final ride heights and weight percentages, you should obviously finish off with a good alignment.
Hope that helps.
Old Feb 5, 2006 | 09:18 PM
K9MINI's Avatar
K9MINI
Wow I am overwhelmed to say the least Well thanks for all the detail. I am going to have to know this stuff inside out if I am going to run my car with all the bells and whistles. Thanks for that detailed info...now my head hurts :impatient
Old Feb 5, 2006 | 09:29 PM
Coopernicus
One more thing - if YOU want to be the one doing the actual adjustments or observing the process instead of just sitting in the driver's seat, then either find someone else that's about your weight to sit there in your place (tell them to be STILL ), or you can simulate your weight with sandbags or weights 'borrowed' from your favorite gym .
Old Feb 5, 2006 | 10:04 PM
Coopernicus
And another thing...
If you intend to auto-x or track your car, then set the car up as CLOSE as possible to the condition it will be raced in.
Get rid of any stuff in the cockpit or boot that wouldn't be there when it's on track. If you typically autocross with very little gas, then show up at the scales with the tank nearly empty (remember that gas weighs 7 pounds per gallon... and this exercise is all about WEIGHT!!).
If you swap your heavy street wheels with really light wheels for events, then put the light rims on before boarding the scales. Though most percentages of weights would not change since all four wheels weigh the same, this is a golden opportunity to find out EXACTLY what your car weighs in race trim.
Old Feb 5, 2006 | 10:21 PM
Dr Obnxs's Avatar
Dr Obnxs
The alignment shop I use described it this way...
If you think of your car as a four legged table, the corner balancing is akin to changing the length of the legs so it doesn't rock.
Not a perfect analogy, but close.
Also, you won't change the wight distribution much, the Mini will always be front biased.
But you will get the best traction you can out of the adjusatable shocks.
Matt
Old Feb 6, 2006 | 03:09 AM
SpiderX's Avatar
SpiderX
. . . . .X
Hope that helps.
I had my car done a few years ago and from what I can tell your explanation sums up very well the process i witnessed.....nice job...
Old Feb 6, 2006 | 03:22 AM
jlm's Avatar
jlm
bump steer (not a good thing) is a condition where toe changes with suspension movement. it depends on the geometry of the linkages and may or may not be present. the mini has very little.
Old Feb 6, 2006 | 06:42 AM
meb's Avatar
meb
I think this is a great explanation! Just don't forget that you or an equal weight depicting you must be in the car during this operation.
Final thought; becasue your weight is part of the calculation, the weight left to right over a given axle will more than likely not be the same. It is important to get to 50% cross weight. Your car will be very predicitable in terms of weight transfer if you can do this. Getting left to right weights the same requires moving stuff around. If you can accomplish this it is a good thing...probably not possible...
. . . . .X
Hope that helps.
Old Feb 6, 2006 | 07:54 AM
CFMINI's Avatar
CFMINI
Very good info. So how much (approximately) should a corner balancing for a MINI cost at a shop? - for example a car with Bilstein PSS9's.
Old Feb 6, 2006 | 08:05 AM
RED FURY's Avatar
RED FURY
Most "regular shops" can't do it, you need a race shop, that preps cars for the track
Old Feb 6, 2006 | 08:47 AM
Coopernicus
Let me expand your comment a bit - - your common tire/battery/alignment shop doesn't W.A.N.T to do it!! It requires a very detail-oriented technician and takes too long to fit into the 'meatball surgery' business mentality that runs your typical alignment joint.
I have always done it with just a knowledgeable friend and borrowed scales, so others will have to give you their cost estimates. A well-established race shop that offers this sort of service to customers may charge you a couple hundred bucks due to the time, equipment and expertise required. But I can guarantee it will be worth the effort and $$$ to get the most from the investment in your suspension hardware.
Old Feb 6, 2006 | 08:56 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
The MINI can be 50% cross weighted - our car is.
Great info!
For example's sake, we charge based on the time it takes. Some cars are very close and it doesn't take much fiddling. Others are way off and we charge accordingly. I'd say anywhere from $85 to $200.
Hope that helps!
Randy
K9MINI's Avatar
K9MINI
Thanks Guys!
Anyone know of a race prep shop in the NY/NJ around Bergen or Rockland County?
Old Feb 6, 2006 | 09:01 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
I don't know how far that is from Helix in Philly, but I would give him a call and ask if he knows of anyone. Eric or Dane should know.
Randy
Old Feb 6, 2006 | 10:07 AM
onasled's Avatar
onasled
Good info here. Better then I could offer.
My personal results from last years corner balancing.
Old Feb 6, 2006 | 11:32 AM
meb's Avatar
meb
you can try Meccanics Shop north in Salem, NY. Ask for Anthony. The are times when he is friendly, times when he is not and times when he is aloof.
If you can get into Fairfield county Connecticut I can help with more suggestions - Westport, Stanford.
Hey Onasled! your picture printed an image before the computer downloaded the whole thing...wus up with that . I see you're taking the racing bug thing very seriously
Originally Posted by K9MINI
Thanks Guys!
Old Feb 6, 2006 | 11:40 AM
Coopernicus
- Onasled -
That is a very easy-to-read view of a fine "balancing act" .
BTW - Are those Bilstein PSS9's peaking out from your signature pic? If so, do you think they are a good compromise of ride & handling for a dual-use street/track car? I want coilovers, but don't want a buck board for my daily driver....
THANKS.
Old Feb 6, 2006 | 01:15 PM
onasled's Avatar
onasled
- Onasled -.......Are those Bilstein PSS9's peaking out from your signature pic? If so, do you think they are a good compromise of ride & handling for a dual-use street/track car? I want coilovers, but don't want a buck board for my daily driver....
THANKS.
I recommend the PSS9s highly for the street. They are the perfect system for someone that likes to do DEs and also regular street driving. I had H-sports with my factory struts prior to these, and the PSS9s were much better.
They are coming off though, to be replaced with Motons. And sorry, they are spoken for ...
Old Feb 6, 2006 | 01:30 PM
Dr Obnxs's Avatar
Dr Obnxs
Another quote point...
I'm going in for ride height, corner balance and alignment at Custom Alignment in Mt View. Front and real alignment is $240 (for those that want to know what they charge for an excellent alignement), and ride height and corner balance brings the total to $615. They aren't the cheapest around, but you don't leave until it's right.
Matt
Old Feb 6, 2006 | 01:44 PM
Coopernicus
Onasled -
Thanks for the recommendation. I think that is the direction I will take for suspension upgrades, along with some Helix/RDR camber plates.
Enjoy your Moton experience!! I've "Been there, Done that" with Motons on my Porsche Boxster S back in 2001. Lex Carson and Jerome Van Gool of Moton are GOOD PEOPLE!!
Do they have any Club Sport models for the MINI yet? I simply can't justify $6k for MINI shocks like I did for the Porsche...
