Suspension Rear Control Arm Issues
Old Jan 26, 2006 | 07:01 PM
ctborder's Avatar
ctborder
1234
Old Jan 27, 2006 | 05:15 AM
petecrosby's Avatar
petecrosby
Originally Posted by ctborder
Today I found that my right rear lower control arm is cracked. Well now I am worried about driving the car at all and I need this taken care of ASAP. I was wondering if anyone else had this problem. I would like to know how much it was when you went through mini and how much it was if you had another shop do the work. Also, who has gone the adjustable control arm route and how is that working out for you. I need to replace both because I am really **** about the strength of the parts now.
A number of folks have experienced this. I would not drive the car like this. Have MINI flat-bed it and fix it. It should be covered under warranty.
I have aftermarket control arms on my car. I installed them to allow for
camber adjustment in the rear and had nothing to do with concern over
the factory control arms.
Old Jan 27, 2006 | 05:32 AM
chaincoopers's Avatar
chaincoopers
I replaced mine with adjustable H-sports to allow for camber adjustment after my drop. My factory arms are in fine shape with just under 5000 miles on the car when they were removed. If it would save you some trouble/money, I'd be happy to send you the factory arms if you pay the postage. They're just sitting here. With a set of jackstands, it shouldn't take you but an hour to swap them out yourself.
Old Jan 27, 2006 | 06:53 AM
ctborder's Avatar
ctborder
1234
Old Jan 27, 2006 | 07:04 AM
petecrosby's Avatar
petecrosby
Hmm, your warranty is 5 years or 50,000 miles. Why won't they cover it?
Others have had theirs replaced under warranty. Unless there is evidence
of an impact and because these parts do have something of a history of
failing in the manner you have described, they (MINI) certainly should cover
this under the new car warranty. Ask to have this issue referred to the
zone rep if they continue to give you grief.
Old Jan 27, 2006 | 11:02 AM
ctborder's Avatar
ctborder
That is what I think as well. It should be covered under warranty. But the guy down here isn't listening to me.
Here is the problem;
Old Jan 27, 2006 | 11:03 AM
ctborder's Avatar
ctborder
1234
Old Jan 27, 2006 | 11:10 AM
chaincoopers
Thats crazy..... In any case, you'll have your new control arms on monday. Another dealer should see that though.
Old Jan 27, 2006 | 11:12 AM
petecrosby's Avatar
petecrosby
That crack is consistent with pictures I have seen where others have
had the same problem. Call the zone (regional?) service rep or call MINIUSA
direct.
sandtoast500's Avatar
sandtoast500
Yikes.
That really makes me want to order some stronger arms. I'll save some weight, too!
Are the lower arms a higher priority than doing all of them?
Old Jan 27, 2006 | 11:16 AM
Eric_Rowland's Avatar
Eric_Rowland
..my only problem is that the car has 37,000 miles and they say that isn't isn't something they can cover. ...
That's ridiculous! It's not a freakin' wiper blade (i.e. maintenance) it's a CONTROL ARM!! It would be covered under the warranty (4yr/50K miles), not the 36month/36k mile free maintenance agreement.
ctborder's Avatar
ctborder
Thank you again for helping me out with that.
Old Jan 27, 2006 | 11:17 AM
ctborder's Avatar
ctborder
1234
Old Jan 30, 2006 | 11:33 AM
deerharb's Avatar
deerharb
Considering that most of the Mini is well designed, I am amazed at the way they designed the control arms. Not only are they structually weak but the "mush" metal used is why these kinds of problems occurr.
My lower rear control arms were bent prior to when I bought my Mini. Moss Motors was discounting their non-adjustable units for about $50 a pair (lowers only) late last year. They are made with a square tube, probably CRS, but I am not sure. They could be CroMo. Anyway they are much lighter, stiffer, painted gloss black and you cannot beat the price. Easy install with a few wrenches and jackstands.
Old Feb 2, 2006 | 01:10 PM
trackster's Avatar
trackster
The lower control arms are certainly a weak part on the car. I have seen several cars with that issue. The only permanent solution is to swap out to good aftermarket item. The install is an easy deal with nothing special required.
John
Old Feb 2, 2006 | 01:52 PM
Dr Obnxs's Avatar
Dr Obnxs
Even if you fix it yourself...
Send a nasty letter to the Mini dealership that denied the claim, and to Mini USA. That's frigging rediculous. Stuff like that is EXACTLY what the warranty should cover. Don't be satisfied with this BS.
Matt
Old Feb 2, 2006 | 03:18 PM
rjmann's Avatar
rjmann
To my mind this goes well beyond warranty issue and heads straight to a recall issue. A control arm sheering at speed could easily be catastrophic. Given that others on these pages have experienced this problem, I'd suggest you contact NHTSA. You should retake your photos so that the arm itself is in focus.
From the NHTSA web site
If a safety-related defect exists in a motor vehicle or item of motor vehicle equipment, the manufacturer must fix it at no cost to the owner. Your complaint is the first step in the process.
http://www-odi.nhtsa.dot.gov/ivoq/
Old Feb 2, 2006 | 04:59 PM
saakey's Avatar
saakey
took the words right from my thoughts... That is a serious problem.
Old Feb 2, 2006 | 07:28 PM
ctborder's Avatar
ctborder
1234
Old Feb 2, 2006 | 07:48 PM
TwOMINIs's Avatar
TwOMINIs
I had one (control arm) completley break...I had a tiny scuff on the rim, and the MINI dealer said i must have curbed it and caused a bend and weak spot...yes i do drive aggressivly...warranty denied...it's an '02 and those holes are open on the '02 control arms.
cerenkov
Suspension
14
Sep 18, 2013 04:29 PM
Johan
Aug 12, 2013 04:15 PM
minilites
Suspension
28
May 21, 2008 03:08 PM
freeskier
Suspension
62
May 16, 2008 07:21 PM
limster
Suspension
Jun 16, 2007 12:05 PM
