Drivetrain RC 440CC Too Much?
Old Jan 25, 2006 | 11:13 AM
Minirowski's Avatar
Minirowski
RC 440CC Too Much?
I have talked with RC Inj. company but they have only 370cc and 440cc Inj. right now. If I get 440cc Inj. is it going to be too much?
Old Jan 25, 2006 | 11:15 AM
mybroscoop's Avatar
mybroscoop
for what? what mods are on the car?
Old Jan 25, 2006 | 11:16 AM
kapps's Avatar
kapps
What do you have installed? Unless you have a TC kit or 19% pulley and lots of mods, 440 is overkill and might hurt idle and throw some fault codes.
Old Jan 25, 2006 | 11:18 AM
Minirowski's Avatar
Minirowski
17% + 2% + Schrick + ALTA CAI + ALTA IC
Old Jan 25, 2006 | 11:20 AM
Minirowski's Avatar
Minirowski
JCW Inj. are 420$ and RC Inj.s are 360$. I thought bigger is better
Old Jan 25, 2006 | 11:39 AM
kapps's Avatar
kapps
You might get some benefit but you'll really need an ECU upgrade to make it work. Under the stock program, you'll probably run pig rich.
As for bigger is better... It depends. If your running lean, then you do need bigger injectors. The problem with large injectors is that they can't spray a fine mist as well as the smaller stock system so when they aren't flowing a lot (like at idle), they tend to cause the engine to run a bit rough. Also, you don't want to just dump fuel into the engine; you'll actually loose power. Forced induction cars do need to run a bit rich (say 12:1) instead of the standard 14.7:1 but anything more is just cooling the combustion and loosing power.
Old Jan 25, 2006 | 03:32 PM
Minirowski's Avatar
Minirowski
The thing is I don't know MTH has a program for 440cc. Maybe with SAFC I could get some decent HP.
Old Jan 26, 2006 | 08:55 AM
mybroscoop's Avatar
mybroscoop
You could use an SAFC, but go to somebody that has experience tuning with one.
Old Jan 26, 2006 | 09:02 AM
Cooper_Si's Avatar
Cooper_Si
M7tuning state the following with theyre 440cc injectors....
"These injectors are very high flow units, necessitating the use of outboard fuel computer or similar device, and as such are not recommended for lower horsepower applications"
They also state theyre for 250hp applications so i dont think remaps are viable with this size of injector
Simon
Old Jan 26, 2006 | 09:19 AM
minimute's Avatar
minimute
Simon
Cooper Si, has M7 used these injectors and if so are they re-worked injectors like the 400cc ones? Also, why are they selling something they don't have a system with to control it?
Old Jan 26, 2006 | 11:22 AM
Minirowski's Avatar
Minirowski
They are reworked ones. And they need your old inj. other wise there is a core charge. It's too expensive if you add the core charge to it.
firenewt
Jul 15, 2020 01:30 PM
jcwmini04
Sep 20, 2015 04:52 PM
D-MAN
Nov 5, 2010 12:34 PM
RIPPER
26
Feb 21, 2008 08:33 PM
