Navigation & Audio Its broke! Is it my fault? Please help!
Hi, Newbie here!
Just 4 months with my new 05 Dark Silver MCS and I'm obsessed. My wife says my obsession it’s not healthy, but shares it.
Here's the problem. I’ve never been happy with lack of volume of the HK, but don't want to replace the whole thing. So I installed a 700 watt amp with a pair of 6x9’s pioneers in the back (took the signal for the amp from the rear speakers). It kinda did the trick for a while but this Tuesday out of the blue the radio just shut down
. It seemed like a blown fuse, but no luck.
Here's where I'm lost: this Friday (again out of the blue) the radio turned back on by itself, just to shut down again this morning (now I feel like he's playing with me).
Am I overloading the HK? Did I wired it wrong? Is this common for the HK? It worked fine for about a month. Please help.
. It seemed like a blown fuse, but no luck.Here's where I'm lost: this Friday (again out of the blue) the radio turned back on by itself, just to shut down again this morning (now I feel like he's playing with me).
A speaker-level to RCA adapter would likely reduce the load seen by the head unit. Many amps say you can use speaker-level inputs directly, but this may appear to be an open or short depending on the amp. Try simply disconnecting the amp first.
Now that you mention it, when the radio "fixed itself" the amp was disconected. I'm disconecting it right now. Hope it works.
If that's the case, is there another way to get a signal for the amp without confusing the H/K? I tried lookig for some diagrams but they were too confusing for me.
Lack of volume? With all due respect to folks that complain about the apparent "Lack of volume" of the H/K system, I think you need to see the doctor and check your hearing. You'll be surprised how many people (Specially in our generation) are quickly becoming clinically deaf due to the noisy environments in which we live in. When your hearing is deteriorating, the natural response is to increase the volume of the TV or stereo, because our ears can no longer process sounds at normal, healthy decibels.
Never had a problem with the volume of my H/K.
For H/K technical questions, member GBMINI (Ian Cull) is the person to talk to in this forum.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
MINI Stupor
Oct 1, 2015 11:36 AM
Giants9595
Sep 29, 2015 10:49 PM
