Suspension Which Grease?
Old Jan 22, 2006 | 10:43 PM
kyriian's Avatar
kyriian
Which Grease?
My H-sport sway bar started to make noises after close to 2 years.... i wonder which grease should i use?
Old Jan 23, 2006 | 02:13 AM
BFG9000's Avatar
BFG9000
I used Redline grease on my H-Sport bar because I already had it, but Mobil 1 or even plain moly grease are probably just as good for this very low-stress application.
Old Jan 23, 2006 | 07:04 AM
kapps's Avatar
kapps
Good timing on your post kyriian. I've been meaning to post the same question for a couple weeks now.
Old Jan 23, 2006 | 10:25 AM
kenchan's Avatar
kenchan
i think everyone knows wat i use.... yes, white lithium.
works great, readily available. no squeeks.
Old Jan 23, 2006 | 02:24 PM
Kellzir's Avatar
Kellzir
wrap the bar with teflon tape and use white lithium grease.
Old Jan 24, 2006 | 08:19 AM
norm03s's Avatar
norm03s
Now that's a good idea:thumbsup:
Never thought about using Teflon Tape!
I have always added zerk fittings to the bushing clamps of my sway bars. It's easy and cheap to do.
Then I use a hot wire to melt a path through the poly bushing from the clamp zerk fitting hole to the bar with a distribution slot inside the poly bushing so the grease can spread out along the bar.
I used to mix my own stuff up and load up an old grease gun with it just for sway bar bushings. White lithium grease + one tube of powdered graphite.
Grease them up once a year at most whether they needed it or not, no squeaks.
Old Jan 25, 2006 | 09:28 AM
sanddan's Avatar
sanddan
I use Super Lube, a synthetic grease that contains teflon, It's waterproof and tends to stay where you put it.
The large tube works with a standard grease gun.
Old Jan 25, 2006 | 09:44 AM
kyriian's Avatar
kyriian
is it possible i get the spray type? i dont have my own grease gun to begin with,...
or perhaps just needs an oiler
OutMotoring
Mar 3, 2017 06:29 AM
gknorr
Dec 26, 2016 09:38 AM
theblackfalcon
Oct 19, 2015 05:22 AM
Sep 14, 2015 12:48 PM
Sep 10, 2015 10:52 AM
