Navigation & Audio Bluetooth, iPod, & AUX?
Old Jan 22, 2006 | 09:28 AM
dwfrank's Avatar
dwfrank
I can't seem to find a straight answer to this. Can I install all of this:
  • Bluetooth kit that use MFSW w/ Mike's harness
  • OEM Aux port
  • iPod, likely IceLink+
all to the same head unit? Or are any of these mutually exclusive?
I recall that the configurator turns off the OEM Bluetooth if you pick the OEM iPod and vice versa.
--dwf
Old Jan 22, 2006 | 04:33 PM
hollis3's Avatar
hollis3
Coordinator :: Motoring Underground Club Forum
I'll let you know about a few of these in a couple days...
I am getting bluetooth and AUX and Sirius (installed without AUX).
Old Jan 22, 2006 | 10:56 PM
Edge's Avatar
Edge
AdMINIstrator
Which bluetooth? The modest ~$400 one with an external keypad? The crazy-expensive new $1250 one that taps into your steering wheel buttons, factory stereo and/or factory Nav? Or an aftermarket BT solution?
Old Jan 23, 2006 | 12:32 AM
uglyduck's Avatar
uglyduck
Bluetooth integration for Minis with 3 spoke wheel with phone buttons (Parrot EVO)
I wish these served as a good reference.
Bluetooth integration for Minis with 3 spoke wheel with phone buttons (Parrot EVO),,, click it.
or..
Bluetooth integration for new 3 spoke wheel with phone buttons (Nokia),,, click it.
I guess that you know about them.
I am eager to know the result after using them.
Old Jan 23, 2006 | 06:51 AM
gadgeTT's Avatar
gadgeTT
I can't comment on the iPod integration, but I have the following all peacefully coexisting in my 2006 MCS:
* h/k headunit
* navigation
* Mike's EVO MFSW BT integration (working great!)
* XM through the CD changer input line
* Factory AUX in for my iPod, etc...
No problems with all of the above.
Old Jan 23, 2006 | 07:24 AM
Edge's Avatar
Edge
AdMINIstrator
Yes, I know about them... which is why I did mention "Or an aftermarket BT solution?". I am curious to hear feedback from someone that threw their money at the "fancy" OEM solution though. I'm particularly interested in how it ties into the factory Nav.
Old Jan 23, 2006 | 08:08 AM
mbabischkin's Avatar
mbabischkin
Based on the original poster's comments that he wants Bluetooth with the newministuff harness, I think it's safe to assume that we're talking about an aftermarket kit and not the OEM kit.
Which means that if you have HK you can connect everything to the back of the HU with no problem. Since the newministuff harness essentially has a "passthrough" on it for accessories like you list above you're all set...
Worse case scenario, you don't have HK and have an HU with just 1 accessory connection instead of two. Then you'd have to pick up the CD changer version of the ICELink and run the cable up front.
Keep in mind however when using the ICELink with a Bluetooth kit, when a call comes in on the Bluetooth kit, the iPod audio is only muted, your iPod isn't paused... Probably not a big deal if you're listening to music, but it gets old quick if you're listening to audio books or podcasts...
Old Jan 23, 2006 | 10:03 AM
dwfrank's Avatar
dwfrank
Thanks folks. I didn't realize that Mike's harness had a passthrough.
Since folks are asking, I'm thinking about the following hardware:
  • IceLink+, unless the "new" BMW/Mini iPod adapter turns out better by the time I take the leap
  • 5th gen iPod
  • Parrott 3100 BT kit + Mike's MFSW harness for my Treo
  • Aux port for anything else
All of this is for me to obsess about until my MINI arrives.
Thanks to all,
--dwf
Old Jan 23, 2006 | 12:00 PM
mbabischkin
I haven't seen anything definate on this, but from what I've heard so far the only difference between the Gen1 and Gen2 OEM iPod adapter is that the Gen2 supports (as in works in cars with) the OEM nav system. There are no other changes to the OEM adapter...
Old Jan 23, 2006 | 01:33 PM
krenzkes's Avatar
krenzkes
I have the OEM Bluetooth and it works great. I'm looking to possibly get the ICELink+ for the Ipod Nano I got free from my dealership too.
Old Jan 23, 2006 | 01:52 PM
supergimp's Avatar
supergimp
Funny, I have Mike's kit with the Sony Ericsson BT kit and my audio on my iceLink attached iPod pauses nicely when the phone rings or I place a call and picks up right where I left off when I hang up. One of the things I was really impressed with about the iceLink integration. I wonder why yours isn't working that way? Also the iceLink pauses the iPod when the car is shut off, even though power is retained for charging for 2hrs after (as setup in the iceLink prefs) and picks up where I left off when I turn on the ignition or manually turn on the radio.
I have NAV as well and all works as expected.
I'm curious to see how the Treo works with the Parrot 3100. I have been considering upgrading to Mike's 3100 kit so I can have MFSW integration but friends of mine have been havinga nightmare of a time getting the Treo to work reliably with Parror (not MINI related). Let us know how it goes.
Steve
Old Jan 23, 2006 | 03:32 PM
Edge's Avatar
Edge
AdMINIstrator
Krenzkes... which one? There are two different OEM Bluetooth kits. The older, much cheaper one costs about $400, and has an external keypad. The newer, crazy expensive one costs about $1250, requires the OEM armrest, and ties into the buttons on the MFSW (which were added from 01/05 builds onwards).
I'm guessing it's the former... but I'm hoping to hear some feedback from someone who bought the "fancy" one.
Old Jan 23, 2006 | 03:42 PM
hollis3's Avatar
hollis3
I have bought the TellPhone 4000... It looks great with my interior...
This is their photo...
Old Jan 23, 2006 | 03:56 PM
mbabischkin
It charges like you describe, but it never pauses my iPod. My only option when a call came in was to change the mode that the radio was in. My Bluetooth kit died back in September and I haven't been motivated enough to pull everything out again and figure out what the problem is...
It doesn't help that my current phone, an Eten M500, is giving me grief when I use Bluetooth. That and lately I've just been letting the phone dump to voicemail when a call comes in... I rarely if ever get calls on my cell that can't wait until I check my voicemail...
pglgp1292
Aug 9, 2017 12:45 PM
gar56
Nov 15, 2016 06:41 AM
rikaro
Nov 24, 2015 02:05 PM
krohm
Sep 28, 2015 12:16 PM
