05/05 exhaust on an 03?
The stock exhaust is basically the same '02 to '06, but there are two sets of hangers. One set for '02 to '04 models and another set for '05 to '06 models.
You can use the stock '05 to '06 exhaust on your '03 if you can get a set of '02 to '04 stock hangers.
Originally Posted by DiD
The stock exhaust is basically the same '02 to '06...
The '05 exhaust really doesn't look that much different. The tube coming off the cat has a little dip down in it as it reaches the back of the car (before making the turn around the battery box for the first time).
Originally Posted by greatgro
Will an 05 or 06 stock MCS exhaust fit on a 2003 MCS??? I think my UUC is broken...
I've got an '05 exhaust leaned up against the side of the house, waiting for the next "neighborhood clean up day." You (or anyone else reading this thread) are welcome to it. All you have to do is pick it up or pay the shipping. (Near Sacramento, CA.)
DARN! You're too far.... My exhaust is currently slightly bent inward..
My understanding is that the only difference is that on the 05+ exhaust, the two rear inner mounts (the ones by the battery box) are rotated 90 degrees so that their tips point inward, toward the center of the car. I've heard any muffler shop should be able to heat them with a torch and twist them into the right position.
I'll try to link to an image at RealOEM.com:
Diagram of OEM exhaust parts
Part #11 is the upper half of the right side muffler bracket. Part #5 is the lower part of the bracket. The higher part #11 is the 05+ bracket; the lower #11 is the earlier bracket. See how the inboard side is different? (Part number #12 is the left side equivalent.)
I wonder if you can just get the two earlier-model brackets and mount an '05 exhaust? I'm in over my head here, so I'll let others try to fill in the blanks...
Last edited by dave; Jan 20, 2006 at 12:13 PM. Reason: to make image a link since real OEM doesn't permit hotlinking
patsum
26
May 29, 2021 06:29 PM
embiggenedmini
Oct 15, 2015 12:36 PM
Sep 2, 2015 09:05 AM
